Starter is sluggish
Old Nov 21, 2016 | 08:14 PM
harleymc's Avatar
harleymc
Question Starter is sluggish
I was on an out of state deer hunt with my '95 PSD and suddenly the starter was cranking real slow on start up. My batteries were 5 years old so I assumed that was the problem and went to the nearest town 2 hours away. Arriving at midnight only Walmart was open, so I bought two new batteries with 850 CCA. Problem still exists. Once I got home I went to O'Reillys and they tested the batteries and starter with their diagnostic tool. First the battery tested bad until I cleaned up the lugs, then they tested good. The starter tested good as well, guy said it drew 14 amps, or was it 140 amps? My memory fails as I age... The battery cables are original and I admit that the lug on the positive terminal of the main battery is pretty banged up.
But I still have an issue where at start up it just barely cranks fast enough to get running, and the cold weather hasn't even hit yet. What could it be? Is the starter beginning to fail? Should I get new battery cables? I realize Walmart batteries aren't the best, but they are brand new and have 850cca vs. 750 on the factory installed ones. Any suggestions?
Old Nov 21, 2016 | 08:38 PM
Red97350's Avatar
Red97350
For the price, I would check out the tyc starters on rockauto. It looks like they are $108 without a core charge because they are new. Look for a coupon code too. When I got the starter for my Ex, I got it for $78 shipped to the door. Hope this helps.
Red
Edit:
Check out the starter for a 2002, it's $70.87. I believe the only difference is the terminals for the relay.
Old Nov 21, 2016 | 10:30 PM
Bubba Jones's Avatar
Bubba Jones
I'd also check your positive battery cable over pretty hard (connections on each battery and the starter) as well as the negative battery cables.
I have two walmart batteries (I believe the same as yours) and my Bronco cranks and starts up really well.
Off the top of my head, I can think of 3 things that would cause slow cranking:
1) Bad batteries/ battery connections
2) Bad starter
3) Motor resistance (like if it was almost hydro-locked)
I doubt something mechanical is making the motor harder to crank, your batteries are new, so that should leave your starter or battery connections. I haven't had too much experience with the diesel system yet, but I've had way more than my share of battery connection issues when my Bronco was a 5.0 and also have battery connection issues with my Camaro (Chevy's incredible side post terminal setup has help me build anger and frustration more than I can count.) This motor takes a bunch of juice to actually turn over so if the connection is suffering, it may not turn that starter that well!
Old Nov 22, 2016 | 10:19 AM
knottyrope's Avatar
knottyrope
If starter isn't bad then I suggest this reading this
https://www.ford-trucks.com/forums/1...ou-cranky.html
Old Nov 22, 2016 | 02:11 PM
lee00's Avatar
lee00
I would look long and hard at those cables....any signs of corrosion would be game on for replacement in my book.
Old Nov 22, 2016 | 02:17 PM
fordpride's Avatar
fordpride
My guess would be bad starter.
Tees77f150
15
Jun 27, 2022 04:53 PM
bigenough
17
Apr 25, 2021 07:13 AM
River19
13
Sep 9, 2014 02:55 PM
Lead Head
1983 - 2012 Ranger & B-Series
17
Sep 19, 2007 10:19 PM
scionti 94
1978 - 1996 Big Bronco
Aug 28, 2006 09:31 PM
