replacing wiper switch
Old Aug 18, 2002 | 03:43 PM
kioolt's Avatar
kioolt
Old Aug 19, 2002 | 11:47 AM
D Ray's Avatar
D Ray
How hard is it to replace the wiper switch in a 91 F150?
Old Aug 19, 2002 | 06:47 PM
Mil1ion's Avatar
Mil1ion
Is it part of the signal switch or by itself on the dash?
If it is on the dash,it's easy.
If it is part of the S/S then you are going to need some patience and some special tools,Like a connector removing tool,steeering wheel puller.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Aug 20, 2002 | 06:56 AM
D Ray's Avatar
D Ray
It's on the dash next to the light switch. I haven't even messed with it or tried to take it out but was wondering if anyone had done it before or had any tips.
Old Aug 20, 2002 | 01:25 PM
Mil1ion's Avatar
Mil1ion
They are a LOT easier if you remove the cluster.
Do you have an intermittent wiper system ?
If you do,that would cinch it for me as the ground strap usually attaches directly Behind the cluster.
Do you already know how to Remove the *****?
[/font]
[/font]
Old Aug 20, 2002 | 02:34 PM
D Ray's Avatar
D Ray
I do have, or atleast used to have intermittent wipers. Now they are just 2 speed and I have to jiggle it at an angle for the washer to work. The wiper switch **** is already off of it because it hollowed out the inside of the plastic **** making it a pain to turn on and off. I assume the light switch comes off like the wiper **** did- with that little clip that you have to pull towards you and then slide the **** off.
Does that sound right? If so, what next?
Thanks,
Old Aug 20, 2002 | 05:05 PM
Mil1ion's Avatar
Mil1ion
The headlight **** & shaft are different.
1st Make sure your battery is dosconnected.
Have you removed the Cluster bezel?
You usually get that off next.
The headlight switch **** is tricky.
If you pull the **** out all the way now reach in behind the bezel to the top of the light switch and you will feel a button.
When you press down on ther button pull out the switch ****.
If you do it right ,it should just slide right out.
Most people make the mistake and just pull and pull while pressing the button.They usually end up brealking the switch.
The trick is, to have the switch **** all the way out First >
Then push the button and pull the ****.
This should give you access to the wiper switch.
If you want a replacement intermittent system, I have them for sale but you have to contact me personally Off FTE.
[/font]
[/font]
Old Aug 21, 2002 | 06:12 AM
D Ray's Avatar
D Ray
Is there any trick to removing the cluster bevel?
I plan to start on this little project this weekend. I hope to get the switch locally but if I can't get it around here I'll let you know.
Thanks again for your help mil1ion! I'll let you know how it goes.
Old Aug 21, 2002 | 11:44 AM
Mil1ion's Avatar
Mil1ion
Instrument Cluster Bezel
I'm not too familiar with the 90's.
I'm heading to the wreckers in a few minutes.
I saw a 90 in there 2 days ago,so I'll look at it before I comment.
Look for Mounting screws > Some may be hidden > Like in an A/C vent
[/font]
[/font]
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
