Bondo's bad?
Old Aug 1, 2008 | 02:19 PM
TheSojourner's Avatar
TheSojourner
Question Bondo's bad?
I might be asking for it here, but I have to ask. Seems there's quite a few posts where people moan about Bondo. My NTM (new-to-me) F-100 needs quite a bit of cosmetic body work, but my wife's uncle told me that it's nothing I couldn't fix with a little Bondo. Having worked almost exclusively on old Jap bikes (70's/80's), I never really had to mess with body work. If a tank was shot, you bought or fab'ed a new one- simple as that.
So before I commit high treason or the 8th deadly sin, can someone give me the finer points/commandments of body work? Is Bondo really that bad? Sounds to me like working with the automotive equivalent of drywall mud, and that's bad?
Please hold back the flames, and just give me the high points.
Thanks!
Old Aug 1, 2008 | 02:28 PM
bucks77ford's Avatar
bucks77ford
Bondo's good for smoothing out dents and seams where new patch panels have been welded in. Many people mis-use bondo to try and fix rust holes without repairing with new metal.
Old Aug 1, 2008 | 02:30 PM
fmc400's Avatar
fmc400
MSEE
^^^ That about sums it up.
Old Aug 1, 2008 | 02:37 PM
ford390gashog's Avatar
ford390gashog
A lot of people tend to over bondo. I have seen people fill 3'' deep dents with over 2 gallons of the stuff. Bondo is also not the best body filler. 3M makes good light weight poly body filler and VHT makes crack proof body filler. I tend to use fiberglass enhanced filler for larger dings and use plastic filler to fix seams and body panels.
Old Aug 1, 2008 | 02:40 PM
TheSojourner
He was suggesting it to fill in rust holes in my quarter panels and in the tailgate. See example below...
https://www.ford-trucks.com/user_gal...194733&width=2
So I guess what I'm hearing is, "It's not bad, just often misused".
Old Aug 1, 2008 | 02:53 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
you don't want to use bondo to fix those rust holes in the bed.
You need to use a patch panel.
You can get by with fiberglass enhanced filler, but the patch panel is best.
Bondo has a life of around 5 to 10 years then it may start to crack and has to be redone, so keep that in mind too.
Old Aug 1, 2008 | 03:03 PM
joshc_guitar's Avatar
joshc_guitar
I Agree. If you are going to fix that you need to patch it then use bondo to smooth it out. I always buy the fiberglass enhanced bondo. I find that it works better IMO. But don't go crazy with the stuff.
TheSojourner
I see some stick welding in my future, eh?
Old Aug 1, 2008 | 03:11 PM
joshc_guitar
Yeah, but unless you're going to be runing over Smart Cars, again be sparing. Don't put a 3" thick bead all the way around your patch. Just enough that it's solid and youre not going to accidently knock it off. You don't want a huge bead to show trhough the bed.
Old Aug 1, 2008 | 04:42 PM
NOCO77's Avatar
NOCO77
Also make sure that wherever filler is used, it is not directly exposed to moisture, i.e. old moulding holes. The inside of the repair (inside of the panel) would still have the filler exposed and it will wick moisture, causing worse trouble down the road. Moulding holes should be filled with metal.
Old Aug 1, 2008 | 05:23 PM
77red4x4's Avatar
77red4x4
Following that line of reasoning shouldn't you avoid filling holes from a slide hammer with Bondo?
Old Aug 1, 2008 | 05:27 PM
77red4x4's Avatar
77red4x4
Yeah, you want a patch panel for the place over your rear wheel well. See my gallery for what I did to mine. Bodywork was new to me so it took a long time but it's held up pretty well so far. But my truck is not a daily driver so it's not out in the elements much. If you are lucky you will not have to patch the inner part of the wheel well. Mine was rusted through there, too.
There are lots of opinions in the paint and bodywork forum.... Good luck whatever you decide to do and let us know how it turns out.
Old Aug 1, 2008 | 06:30 PM
BrentNewland's Avatar
BrentNewland
Good point, never thought of that...
From what I know (and I know some people that do $40G+ paint jobs on classic cars, mirror finishes) you should use bondo (or some filler) with a long sanding block (I've seen as long as 3ft. for long straight pieces)to fill in all the remaining imperfections in the final stage. Paying extra attention to those final details before you paint is what makes your paint job look like a show car job instead of a Maaco Presidential Special.
Old Aug 2, 2008 | 03:27 AM
hairyboxnoogle's Avatar
hairyboxnoogle
dont apply bondo over 1/4" if the dent is worse than that do some metal finishing. As far as rust goes... you can sand blast it and put fiberglass on it which works nicely. but if you plan on keeping it... patch it, it will be alot better for you down the road. When you paint, you want the material to be as thin as possible to avoid cracks and chips. The thicker bondo is the sooner it cracks.
Old Aug 2, 2008 | 07:23 AM
BrentNewland
Sand blasting can heat up body panels and warp them, I'm told.
