Power Window Stuck up
Old Aug 20, 2002 | 06:34 PM
Deer Hunter's Avatar
Deer Hunter
[updated:LAST EDITED ON 20-Aug-02 AT 07:35 PM (EST)]its a 1993 ford bronco......ive pulled the door panel.......i tried jumping the switch to make sure it wasnt bad......when i did that i got a spark and it kinda burnt the wire i used to jump it......when you press the down switch u can hear the motor clicking......so is there a short somewhere or is the motor toast?
Old Aug 21, 2002 | 12:59 PM
Deer Hunter
anyone?
Old Aug 21, 2002 | 09:41 PM
groundrat's Avatar
groundrat
You said that you can hear the motor clicking. Have you checked for anything binding. I have seen some assemblies actually get stuck andthe motor wont have enough torque to put it down. Check the rails and all the linkage. Other than that, ohm out the motor. It may be on its way out. Just my $.02.
Bill
Old Aug 25, 2002 | 04:10 PM
redneckdieselmechanic's Avatar
I have the same problem on my 84 F 150. I pulled the door panel and hit the motor a few times with a hammer and screwdriver while having a friend hold the switch down. It worked for a few days. I guess the motor's on its way out. by the way the motor is original from 84. Ford Tough
Old Aug 25, 2002 | 04:14 PM
wahlturfcare
3.0L V6
Jan 31, 2015 05:03 PM
sdg0080
Feb 17, 2010 10:26 PM
barnbuoy
Dec 7, 2008 07:51 PM
jonnyfresh
1997 - 2003 F150
Jan 11, 2008 04:30 PM
lrstaz
1983 - 2012 Ranger & B-Series
Oct 17, 2005 02:16 PM
