possible injector problem
Old Aug 12, 2008 | 09:38 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by whitesdford
Sounds like a trip to the shop is in order. I dont know much about the valve setups in the 7.3's, but could this be a lifter that has gone south? Are the valves adjustable on a 7.3?
No they are hydraulic roller lifters.
The rocker arms are pretty flimsy and the pushrods bend easily.
I strongly suspect something like that is going on due to the black smoke/missing.
If it were grey/blue smoke it would be more serious. Rings, melted piston, etc.
Easy enough to fix, pull the rocker pedastal assembly, replace parts. Bolt it back down.
Old Aug 12, 2008 | 09:55 AM
whitesdford's Avatar
whitesdford
Great, ill start the process of looking. Got a 50 50 shot of pulling the correct valve cover, haha.
Thanks a bunch for your help.
Old Aug 12, 2008 | 11:54 PM
Kwikkordead
FWIW, I just R&R my valve covers this afternoon, retorqued the pedastals and injectors again in prep for a vacation trip and got it done in less than two hours.
It looks like an intimidating job until you do it a couple of times.
All the rocker pedastal bolts but one were still tight.
EVERY injector took about 1/6 turn to get to 120 inch pounds.
For some reason they really like to loosen up.
They weren't as bad as the last time that I checked them, but more time had gone by as well.
I think this is the last time I need to go back in for a long time.
t_dickie
Apr 10, 2013 08:07 PM
fishbreath
Sep 1, 2012 09:45 AM
vinny80
May 10, 2011 02:10 PM
2002 F350V10
1997 - 2003 F150
Jan 5, 2011 08:59 AM
camodown
Jan 6, 2009 06:34 PM
