C6 Kick Down Shaft Seal
Old Jul 25, 2008 | 11:55 PM
Mudflappus's Avatar
Mudflappus
Hi everyone, I had a minor leak around the kick down shaft on my C6 for quite awhile. My 40 year Ford transmission guru told me that they all eventually start leaking as the square cut o ring isn't designed to hold back the head pressure of the oil when the vehicle sits without running for a period of time. I removed the linkage, RTV'd the area around the o ring and reassembled everything minus the linkage so it doesn't move. I know it's a cheesy repair but I figure I can just pull it down into second from the colunm if I need to pass someone that badly. Has anyone else had this problem? I'm just curious.
This is a 73' F250 Camper Special with an 81' 400M/C6 combo instead of a 390.
Old Jul 26, 2008 | 12:27 AM
mark a.'s Avatar
mark a.
RTV sealer doesn't work well in trans oil. The O ring is easy to replace but more than likely the shifter seal is leaking.
Old Jul 26, 2008 | 08:41 AM
crewcabwannabe's Avatar
crewcabwannabe
A good idea, but your RTV fix won't make it very long.. If you replace only the kickdown's o-ring, it'll take 15 minutes and you don't have to open the tranny- just remove the kickdown linkage, neuteral safety switch, clean out the rtv boogers, exchange o-rings, reconnect the linkage and you're done.
OR- to be really sure, drop the tranny pan and valve body and replace the gear selector shaft o-ring from the inside (you can know zero about trannys and do this easily).. I just did this repair- it will take you an afternoon and about $2.00 in seals. Gives you a reason to clean the tranny filter (free) and replace the fluid too (another $20.00). It was a messy job, but no more leaks, and with the clean filter and fluid, the truck shifts better now.. good luck!
BainbridgeBrewer
Jun 16, 2017 11:11 PM
dthut
May 18, 2017 08:01 PM
dthut
May 18, 2017 07:59 PM
wc870
May 8, 2016 07:20 AM
gifuneod
18
Aug 20, 2007 03:26 PM
