leaking trans question
Old May 18, 2017 | 07:30 PM
dthut's Avatar
dthut
79 F250 - C6 transmission
hey guys, my transmission is leaking oil around the gasket and also from the linkage.
i want to drain the fluid and put a new gasket in, and replace the o ring for the linkage.
ive never done this before, and wondering if there's anything should know. and also if i should do anything else while it's open, like the filter?
any tips would be a huge help. CHEERS
Old May 18, 2017 | 08:01 PM
Shortbox4x4's Avatar
Shortbox4x4
Being as your dropping the pan....replace the filter before you put in fresh fluid.
Also what I did on mine was I drilled a hole in my pan (lowest point of the pan) and I installed a retrofit drain plug. This way you can drain the fluid (at least the vast majority of it) with out it going every where. Here is a link to one.
https://www.summitracing.com/parts/sum-g1380/overview/
It's really easy to do.
Later, Shortbox4x4
ironbender
6.7L Power Stroke Diesel
Mar 28, 2019 11:07 PM
dthut
May 18, 2017 07:59 PM
GSSF17
6.2L V8
22
Dec 30, 2016 01:22 PM
Robby Nash
Oct 22, 2013 03:38 PM
351beast
Jul 10, 2006 09:10 PM
