Oil & Lubrication
Mercron Syn vs. Mercron V
Old Jul 24, 2008 | 08:41 PM
gabocar's Avatar
gabocar
Hi:
I really confused about which will be my best option to change the oil of my 4R100 trans.
I've been reading about avoid use of Mercron V in my 99 5.4L SOHC Navigator, but my questions are:
1.- Can i use Mobil 1 Synthetic ATF?
2.-Is the synthetic ATF mercron V? or not necesarly
3.- Which will be the nest ATF for my tranny?
Thanks for any advice, i'm really confuse.
Gabo
Old Jul 24, 2008 | 10:04 PM
rebelyell618's Avatar
rebelyell618
Mercon V is now what is reccomended for the 4R100. the formula has changed from when Mercon V first came out.
but any fluid that is rated for Mercon or Mercon V is alright to use in your transmission.
Old Jul 25, 2008 | 08:49 AM
gabocar's Avatar
gabocar
I´ve reading nightmares stories about the use of Mercron V in the 4R100.
So, Is the new "edition" of Mercron V safe for 4R100? or I use ATF Synt for go to the safe way?
Thanks for the advices.
Gabo
Old Jul 25, 2008 | 11:06 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Maybe that wasn't clear enough. Does this help?
ANY FLUID THAT IS EITHER MERCON OR MERCON V IS SAFE FOR USE IN YOUR TRANSMISSION.
Ford changed MERCON V from it's original specs to make it compatible with the 4R100 and all other transmissions that used to use MERCON.
I like Mobil 1 synthetic ATF for the 4R100.
Old Jul 30, 2008 | 03:58 PM
ford390gashog's Avatar
ford390gashog
You also cannot buy Mercon/DexronIII fluid any longer its not sold. Ford and GM stopped licenses a year ago. Most companies still sell this new "multi vehicle ATF" which is supposed to be the same but with no quality control from GM or Ford who knows if the fluid is a quality fluid.
Old Aug 21, 2008 | 11:10 PM
BigNiner19's Avatar
BigNiner19
I just got a 2004 Ford F150 4.6L with automatic tranny. I read the owners manual and it said to ONLY use Mercon V for the transmission fluid and that it COULD NOT be mixed with regular Mercon.
It said to use regular Mercon for power steering fluid.
I need to change out my transmission fluid and filter...any recommendations on fluid that I can pick up locally?
Cory
Old Aug 22, 2008 | 06:32 AM
pawpaw's Avatar
pawpaw
Cory
Re-read Marks #4 post, it's all in there.
Old Aug 22, 2008 | 07:46 AM
BigNiner19's Avatar
BigNiner19
So this must have been a change after 2004 when my owners manual came out?
Anyone know exactly what transmission I have? The owners manual seems almost worthless aside from a few thing in my opinion.
My truck is a 2004 F150 XLT 4.6 V8 Regular Cab Automatic Transmission
Cory
Old Aug 22, 2008 | 08:08 AM
projectSHO89's Avatar
projectSHO89
Yes. SEARCH keywords "MERCON TSB"
Cory
SEARCH keywords "transmission code" Use the TR code on your door label.
Steve
Old Aug 22, 2008 | 08:50 AM
Mark Kovalsky
Yes, Ford announced the change in 2006. The last MERCON license expired in June, 2007.
Anyone know exactly what transmission I have? My truck is a 2004 F150 XLT 4.6 V8 Regular Cab Automatic Transmission
All 4.6L F150s have the 4R70W trans, which required MERCON V before this change.
Old Aug 22, 2008 | 08:53 AM
pawpaw's Avatar
pawpaw
Cory
Yup things are a changing!!!!
For those that use the Dealer for service, he keeps up with all the changes, for those of us
who do our own service, it's up to us to keep up to date on all the changes & as Mark has said, Mercon-V tranny fluid has been reformulated, so that it can also be used in previous Mercon call outs, like transmissions & power steering systems.
Scroll up to the top of the page & click on "Full Text" TSB's & enter your year, there you'll find a whole bunch of full text TSB's on your F-150, among them the change in tranny fluid specs & a whole bunch of other interesting things, some pertaining to other models as well.
Old Aug 22, 2008 | 12:04 PM
BigNiner19's Avatar
BigNiner19
Okay. So I read the service bulletin in "full text" at the top of this page. Very interesting, it has all the recalls and good stuff from my model year. I still have one question though. The page said that Regular Mercon is no longer being made so now Dual purpose Mercon OR Mercon V can be used as power steering fluid.
I have a quart of Valvoline Dexron III/Mercon Automatic Transmission Fluid. This fluid should be suitable for adding power steering fluid to my truck right?
It still sounds like Mercon V is the only fluid that should be used for the transmission itself though. If anyone can tell me if what I have is safe for the power steering, that would be great.
Cory
Old Aug 22, 2008 | 06:56 PM
Rockledge's Avatar
Rockledge
What you have is safe for the power steering.
Old Aug 25, 2008 | 04:18 PM
big poppa's Avatar
big poppa
Just changed the powersteering fluid out this afternoon in the wifes 97 Expy with the Mercon V. No problem..
kawika
49
Jun 23, 2021 11:47 PM
Skauber
18
Apr 2, 2017 07:45 AM
RealtorTim
Feb 18, 2017 06:41 PM
Skip1970
Jan 24, 2017 02:57 AM
Rich in CO
23
Jun 17, 2006 02:37 PM
