Sponsored by: Real Truck
Front End "Clunk" while turning
Old Jul 22, 2008 | 10:58 PM
Fluid Power's Avatar
Fluid Power
I've got a real annoying Front End "Clunk" while turning in my '04 F350, any speed, but usually when I hit a small bump or I'm cornering hard.
I've been trying to diagnose this problem for quite sometime now. I've replaced the Ball joints...made no difference. Completely removed the swaybar...made no difference.
I checked to see if the shackles were hiting the frame....they're not.
I checked to see if the brakes were hitting the rims.....they're not.
Could it be the shock eye bushings?
Maybe the power steering gear?
Any Ideas ?
Old Jul 22, 2008 | 11:07 PM
LaxPlaya21's Avatar
LaxPlaya21
How about the track bar?
Old Jul 22, 2008 | 11:09 PM
Gmcbuffalo's Avatar
Gmcbuffalo
I had the same clunk sounds on turning and I thought it was the muffler hitting the frame. Took it to the Ford dealer and they replaced the "front sway bar end links" noise gone.
GregM
Old Jul 22, 2008 | 11:13 PM
Fluid Power
It's not "obviously" loose by hand-wiggling it. Is there a better way to check it?
Old Jul 23, 2008 | 11:14 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Just re-torque the track bar - it takes a LOT of torque
Old Jul 27, 2008 | 06:27 PM
scooterscott's Avatar
scooterscott
i went through the same thing.......replace your front sway bar links and it will solve your problem
Old Jul 27, 2008 | 08:26 PM
spinella's Avatar
spinella
he said he removed the sway bar-still made noise.how about your shocks how old are they?how many miles on your truck?
Old Jul 27, 2008 | 10:38 PM
biz4two's Avatar
biz4two
Arrow
Had a similar problem and took my SD in to the shop this past week. Thinking the ball joints had seen better days, but turned out to be the drag links (I think that is what they are called). It's the bar that goes from the axle to the pitman arm. Both sides were totally worn out. The mechanic with C-channel pliers while the truck was up on the lift...showed me the amount of movement. I was shocked...but now that they were both replaced and greased...NO more CLUNK!
Hope this helps...
biz
Old Jul 28, 2008 | 11:01 AM
Keith Smith's Avatar
Keith Smith
You haven't said, so I'll ask. Did you check to be sure your hubs are not locked (assuming you have ESOF). They could be locked, even though they are set to Auto and cause a similar noise and feeling. That's how I noticed mine. My vucumme lines were rotted on the inside.
Old Jul 28, 2008 | 08:21 PM
bmvtr's Avatar
bmvtr
ive read about this it could be the cab bushings are loose
Old Jul 28, 2008 | 08:30 PM
XLnAK's Avatar
XLnAK
Old Jul 28, 2008 | 08:34 PM
XLnAK's Avatar
XLnAK
I was trying to quote.. But I to have a clunk, that seems to come from that area, so I'll look at the track bar next. Just installed new shocks with no change, just less frequent.
Old Jul 29, 2008 | 08:59 PM
XLnAK's Avatar
XLnAK
Found my clunk today. Placed a 4ft piece of square tube between the spring and sway bar and pried up alittle and there it was. the lower end-link inner portion moved surprisingly out and down, and made a clunk. I had seen a tech use a long pry to check ball-joints and such. If your so inclined you might try it, I suggest placing wood or such in between to protect the rig (or firm rubber.). I first used a jack stand to pry upward on the sway bar then the link itself and found nothing. Good hunting.
Old Jul 30, 2008 | 11:09 PM
Fluid Power
Got my truck back from Ford after they had the cab off (head gasket job). Now the Clunk is gone. At this point I'll assume it was a loose body mount.
BruceJeremy
1997 - 2003 F150
Oct 26, 2011 11:59 AM
timbersteel
Oct 14, 2010 04:08 PM
CraigK
Jan 10, 2010 02:57 PM
Bob Gervais
Mar 2, 2006 04:39 PM
