air conditioning
Old Jul 21, 2008 | 02:22 PM
MIKE 04 GT's Avatar
MIKE 04 GT
air conditioning
i have a 79 f150 4x4. it has a 351c in it. how do i put in ac. it is not an opion now. any advise apriceated. i am new to this all.
Old Jul 21, 2008 | 03:01 PM
OldMetal's Avatar
OldMetal
The best advice I can give you is to buy a kit to fit your rig and follow the directions, you can always ask on here for more details, but for now you are asking somebody to write you a book.
Old Jul 21, 2008 | 03:07 PM
MIKE 04 GT's Avatar
MIKE 04 GT
i did not know if some one had a link to a web site. but thanks
Old Jul 21, 2008 | 03:13 PM
OldMetal's Avatar
OldMetal
There's an A/C section on these forums, you might try those guys.
Old Jul 21, 2008 | 03:15 PM
MIKE 04 GT's Avatar
MIKE 04 GT
i am new here, i did not see them thanks.
Old Jul 21, 2008 | 03:42 PM
OldMetal's Avatar
OldMetal
Cooling, Heating, Ventilation and A/C - Ford Truck Enthusiasts Forums
Here's the link for you Mike, sorry I can't be of much help but installing a A/C system takes some work.
Old Jul 21, 2008 | 09:46 PM
lostinfords's Avatar
lostinfords
Mike 04 GT, I bought a truck w/ the aftermarket a/c system that fit behind the glove box and only had to drill 3 small holes in the firewall for the drain and 2 hoses and I installed factory brackets on engine. Been using it for years w/ no problem. Forgot to mention, that I took factory a/c dash and used it in truck so it looks stock w/ exception of 2 ***** next to center vent. Some guys say that you can take firewall from donor truck as template and cut to fit and adapt factory system, me, I have not yet mastered that ability....but I am getting close as the years catch up to me! They also sell the under dash units, never had one so I don't know how they look or work, sorry. The system I set up was easy to install. I may be parting out the s/c that it is in soon, pm me if you are interested, as a later option.
Old Jul 22, 2008 | 06:59 AM
MIKE 04 GT's Avatar
MIKE 04 GT
lostinfords i am defanitly interested in the kit but i dont know how to pm you. sorry all this forum stuff is new to me ha ha.
Old Jul 22, 2008 | 09:19 PM
427SOHC's Avatar
427SOHC
I have a couple pictures in my gallery of my 79 no AC cab and what the AC cab firewall looks like.
Do you have any junk yards you can check in?
When I bought my parts it was 10 years ago, however there are two yards in my area that have a few of these AC trucks. I more than likely would be able to pick up what I need now for around 175.00, might be less.
These 2 yards are more focused on steel prices now more than selling parts, and the 175.00 I would pay is worth far more than what scrap prices would bring for the weight of the items, however I would have to spend a little time there removing these parts myself since they would not want to waste thier own time with it.
I do however visit these yards enough to have established a decent working relationship with the owners.
I remember spending approx 4 "SCORCHING" hours in the junk yard that July day tagging and removing all the parts I needed and cutting the firewall section.
I try to avoid the more well known junk yards and search out the smaller ones with less overhead. They are still out there.
What is really sad is that when I cut the cab in the photo it was summer 1993, the truck sat in pieces for 13 years before I started working on it again and by then my focus changed after I put in the fatman IFS and the Lincoln 4.6 engine in it.
Believe it or not I welded in a solid piece of steel over the existing firewall to accomodate the 93 Lincoln Mark 8 AC plenum that is bolted to the firewall now along with the dash.
All the parts I had in boxes for the AC and the template I cut from the donor firewall I sold on ebay last fall.
When I cut the firewall section from the donor I used a small pair of metal snips that are made by Jilson co. inc. They will get in some really tight areas and I also had 2 replacement blades available when I cut it out but only needed one(yes the blades will break if they are in a bind) There web site is listed below.
A good battery powered sawzall would work well too.
Jilson
I have the J1451SS set, I bought them from the Matco dealer back in 1990 and use the frequently.
joeskeeter
Feb 21, 2008 10:23 AM
nobull4x4
Jan 23, 2005 03:55 PM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
4x4x4x4
Sep 30, 2002 03:55 PM
stoab
Sep 10, 2002 01:13 AM
