grinding gear while shifting
Old Sep 8, 2002 | 10:30 PM
stoab's Avatar
stoab
I have a 93 F 350 with a 460 4x4. When shifting between low 4x4 an high 4x4 gears grind. i had to turn off the truck to engage the 4x4. is this normal?
Old Sep 9, 2002 | 12:15 AM
Brian460's Avatar
Brian460
Does this truck have an auto tranny?
Old Sep 9, 2002 | 10:25 AM
cbwarrior's Avatar
cbwarrior
Post grinding gear while shifting
Old Sep 9, 2002 | 04:33 PM
JScott488's Avatar
JScott488
Mine does the same thing...I don't know what causes it though... It feels like my driveline is still spinning, even with the tranny in neutral and the foot brake applied. I don't shut mine off. I probably should do that instead of just slamming it into 4x4 hi.
Jon
1995 F-150 XLT 4x4 302 AODE, 31X10X50 Goodyear
Old Sep 9, 2002 | 11:32 PM
Brian460's Avatar
Brian460
With an auto tranny in neutral you still have the fuild moving around inside which will cause the output shaft to turn once the trasfer case gets to neutral, that in turn can cause a slight grinding when going from low range to high or vice-versa.:-)
Old Sep 10, 2002 | 01:13 AM
stoab's Avatar
stoab
yes it does,it the overdrive trani.
woodcraft1
1983 - 2012 Ranger & B-Series
Feb 18, 2015 07:45 PM
fisher4life
Sep 30, 2014 08:28 AM
7.3dieselMike
Aug 24, 2014 04:24 PM
BigAl250
Feb 19, 2014 01:10 PM
77F-150
Feb 2, 2014 10:20 PM
