** HELP!** '90 F-150 Instrument gauges lost power
Old Dec 6, 2002 | 10:31 AM
jettfuel's Avatar
jettfuel
Post ** HELP!** '90 F-150 Instrument gauges lost power
I have a '90 F-150 Inline-6/ 5-speed and when I got in it last night and drove home the gauges weren't working. The lights on the instrument cluster came on, the speedometer works, but no tach, no temp, no volts, and I think the fuel gauge and oil pressure are not working either. When you first turn the key on the engine light doesn't come on, and the parking brake light doesn't light up either.
Anyone have any ideas? I checked all the fuses in the fuse panel, and checked the back of the instrument cluster to be sure the harness was still connected. I know the instrument cluster is getting power because when I turn on the headlights, the dash lights come on. Please help!!
Old Dec 6, 2002 | 12:16 PM
Mil1ion's Avatar
Mil1ion
Possibly, the instrument cluster voltage regulator.
After turning the key to on.
Take a multimeter & Go to the temperature sending unit to check for a pulsing current.
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Dec 6, 2002 | 12:43 PM
jettfuel's Avatar
jettfuel
>Dennis
Hey Thanks for the reply Dennis, Should there be a pulsing current or no current at the temp sender?
Jett
Old Dec 6, 2002 | 12:55 PM
Mil1ion's Avatar
Mil1ion
A Pulsing current will verify the ICVR is working.
You could also use a test light,the M/M tells how much current though.
Dennis
[font color=red]
[/font]
Old Dec 6, 2002 | 05:48 PM
jettfuel's Avatar
jettfuel
Hey thanks Dennis.
On the '90 they didn't have a voltage regulator in the instrument cluster, Ford quit using them in '87. I checked the wiring diagtram and talked to Ford parts guys. All they could say is remove the cluster and look at the printed circuit board to see if is shorted out somewhere.
Anyone have any other ideas?
Old Dec 6, 2002 | 11:16 PM
steve83's Avatar
steve83
Look in the wiring diagram for the fuse that feeds the coil - it also feeds a fuse for the instruments. About a month before my coil died, that fuse blew. Find out exactly which fuse it is & recheck it. Then pull the cluster and check for power on the wire from that fuse.
Old Dec 20, 2002 | 09:06 AM
robertplattbell's Avatar
robertplattbell
The first thing in the manual is "check fuse". In the 1995, all the stuff you mention goes through fuse #17. Check that.
Old Dec 20, 2002 | 02:03 PM
jettfuel's Avatar
jettfuel
Well Here is the update.
After about a week of the gauges intermittently going on and off and still not finding anything wrong in the wiring or cluster itself I decided to start back at the fuse panel like steve83 said. I checked fuse #18 ('90 instrument cluster fuse) in my fuse panel and it "LOOKED" good. I then tested it for continuity and low and behold, NO CONTINUITY! So I quickly threw in a new fuse and VIOLA, insturments work again!
I feel like a fool but at least no one knows what I look like on the board!
I guess the lesson is always check the small things first!
THANKS AND HAPPY HOLIDAYS TO ALL THOSE WHO HELPED
Jett
Old Dec 21, 2002 | 11:27 AM
steve83's Avatar
steve83
You should also look for the problem that caused that fuse to blow to begin with. On mine, it was a coil on the verge of going out. It left me on the side of the highway 2 weeks later. $30 for a new one at CarQuest.
Old Dec 21, 2002 | 11:34 AM
steve83's Avatar
steve83
jasindude1
1978 - 1996 Big Bronco
Feb 26, 2017 04:10 PM
TexasGuy001
Jan 15, 2016 02:56 AM
stephsG37
Electrical Systems/Wiring
Jun 8, 2012 11:44 AM
callman
1997 - 2003 F150
Jun 2, 2008 04:01 PM
haviation
Sep 28, 2003 05:51 PM
