It appears that my truck's instrument cluster is having an issue. The oil pressure gauge stopped working and so did the Check Engine light. It no longer comes on when the key is turned on. Is it likely they are related?
After replacing the sending unit it works intermittently. I think the 90 degree push on connector has a bad connection inside the rubber protector. I'd like to replace it with a ring terminal, but can't find a nut that fits the stud. Does anyone know what size fits?
