Anyone do this mod?
Old Jul 20, 2008 | 12:56 PM
  #31
Izzy351's Avatar
Izzy351
Awesome thread, guys. The fuel pump is my next "major" project (I'll probably roll my own FASS). I've already done the in-tanks & CCK, so I've seen those improvements. Now to tackle the pump & pre-filter so I'll be ready for the larger sticks & turbo. But the first thing I'm doing when I get home is to add the pressure gauge so it can be seen from the cab. I still have no idea what my fuel pressure is doing.
Old Jul 20, 2008 | 01:03 PM
  #32
John311t's Avatar
John311t
You would want to make another one. People are doing it from the same pickup, but using a second one is the way to go. If you want to run them in parallel at least. That way there would be no starvation of the pumps by them both trying to pull from the same small pickup. Another benefit if one pump goes, the second one will still be running. With two pumps pumping, your pump life should go up, since you are now only needing half the fuel unless your on the throttle hard.
I just deleted my avatar, my truck doesn't have stacks anymore lol. Going with a full exhaust, since I never got the benefit of owning this truck with one, had a 5" side pipe when I bought it, I had two different sets of stacks, now I am back to a side pipe, waiting for my new exhaust to come in. Should be a nice new change.
Old Jul 20, 2008 | 01:04 PM
  #33
Farmboypowerstroke's Avatar
Farmboypowerstroke
don't mean to be dumb, but whats the CCK?
Old Jul 20, 2008 | 01:09 PM
  #34
ron's power stroke's Avatar
ron's power stroke
ok.... thought my eyes where going bad lol or my mind....thanks for the info...
CCK = Dino Fuel Alternatives: Cross Connect Kit, Modified Fuel Systems
Old Jul 20, 2008 | 01:18 PM
  #35
Farmboypowerstroke
ok thanks, i guess the CCK mod isn't going to give you any more power, just make the engine run a little better (less noise)
Old Jul 20, 2008 | 01:25 PM
  #36
ron's power stroke
pretty much yes..it does nothing for feeding more fuel...other then taking the air out and balance the rails out....but is still worth the cost...
Old Jul 20, 2008 | 01:33 PM
  #37
John311t's Avatar
John311t
You haven't installed the new HPOP yet Ron?
Old Jul 20, 2008 | 01:38 PM
  #38
ron's power stroke
not yet...every time i get the cash for gaskets..some thing comes up..i needed donuts so i went and got some and ordered the gaskets..the next day found a set of IH bellows for 190 at my door .i couldnt resist so i bought them...should be here tomorrow..couldnt swing for the gaskets so there still on the shelf at the dealer...luckly i didnt put the donuts in.....any one need donuts?? i have a set of stock and the small block chevy donuts....
EpicCowlick
Nov 17, 2024 04:38 PM
Brandon Figueira
Jun 12, 2014 09:55 AM
EpicCowlick
6.7L Power Stroke Diesel
103
Mar 14, 2014 01:48 PM
