General Automotive Discussion
Wife's Trailblazer!
Old Jul 18, 2008 | 01:31 PM
4wheelfurry's Avatar
4wheelfurry
Don't go and buy anything yet! Cylinder #3 is famous for missfiring!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
When it rains or you wash your car water is channeled to the center of the weatherstripping and straight on top of cylinder #3. My wife drives one and this has been a problem for us more than once. GM does have a replacement weatherstripping but at MY cost! F%$&k that it should be a recall for emissions related problem.
But at any rate, take the coil out and blow out the hole with air. Clean the coil and put it back together, everything should be fine!
Old Jul 18, 2008 | 03:23 PM
michaelrob2's Avatar
michaelrob2
Hey cool! Maybe I will buy a can of electrical contact cleaner though!
Old Jul 18, 2008 | 06:23 PM
Autoglass's Avatar
Autoglass
Got
Mechanic
Coming!
Translation, Keep Him OR Her on retainer!
Gross
Mistake
Confirmed
Need I say more?????
Old Jul 18, 2008 | 11:23 PM
kermmydog's Avatar
kermmydog
If you can't figure it out there is a good Trailblazer Forum called trailvoy.com There are some good guys over there. We owned an 04 TB 4x4 drove it to 75,000 miles before selling it. We bought a used 1997 Blazer 4x4 & I like the Blazer better. Not to ARGUE but the 4L60s are not JUNK trannys. I burned one so bad that the fluid was coming out the vent tube & drove it another 100 miles pulling a 5000# trailer. I had it flushed, new filter, & pan gasket, added some LubeGard & the tranny is running great 4000 miles later. Try that with an Explorer. The Trailblazer is a nice truck but there are too many things that are too costly to fix on them. Fan Clutch is $450 because it is operated by the computer. But most new trucks are too costly too fix. I guess that is why I drive older used stuff.
Old Jul 19, 2008 | 07:19 AM
Gevans17's Avatar
Gevans17
Question re Trailblazer
[quote=Moore558;6359557]I've done my fair share of work on trailblazers at work. The 4.2L motor uses coil on plug that is similar to the COP on a ford mod motor. The coils are kinda buried under the upper intake tube and silencer assembly. There are 2 10mm bolts that you have to remove that are on the right side of the box (standing in front of the truck looking at the engine). Take those two off and the intake hose off and it will lift up. There you will see the coil packs which are held in by one 10mm bolt each. Remove the connector and lift the entire coil out.
What is the trick to getting those connectors of the coil? is it held with a clip?
Old Jul 19, 2008 | 10:22 AM
michaelrob2
The connector to the coil has a small clip under the "dome" at the bottom of the connector. Just pry a little and wiggle off.
OK I looked at the coils on #3 and #4 cylinders. They looked clean. I also replaced those two spark plugs. #3 spark plug did look more worn than the #4 plug. Truck seems like it runs a little better but I am thinking that a new ignition coil would be in order.
Old Jul 19, 2008 | 04:10 PM
rebocardo's Avatar
rebocardo
re:which is #3
Chevy V-8 (not firing order)
8-7
6-5
4-3
2-1
So, #3 cyl would be the second one back, driver's side. Or from the posts, the one where all the water dumps
Old Jul 19, 2008 | 04:39 PM
Moore558's Avatar
Moore558
What you can try doing is swap the #3 coil with #2 and see if you get a code P0302 for misfire on #2 cylinder. If you do then you know you've got a bad coil. If it stays missing on #3 then we'll try something different.
Old Jul 22, 2008 | 01:28 PM
michaelrob2
Okay, I just replaced coil #3 and she's purring like a kitten!
BIG thanks to you guys, especially Moore
Old Jul 22, 2008 | 07:03 PM
bigdaddyII's Avatar
bigdaddyII
Any ideas?
Glad you got it fixed. In case it happens again where you need an idea though, this is what my uncle did with his:
Old Jul 22, 2008 | 09:45 PM
rebocardo's Avatar
rebocardo
ouch, I guess that is where crush zones come into play on newer vehicles.
Old Jul 23, 2008 | 12:43 AM
kermmydog's Avatar
kermmydog
It doesn't take much to smash up the TB. I tore off the front & rear plastic just 4 wheeling. One thing I like about the BLAZER better ground clearance & not all that plastic crap to tear off.
Old Jul 23, 2008 | 10:35 PM
  #28
brown 4x4's Avatar
brown 4x4
Wow, seems like everyone here thinks Trailblazers are junk! I work at a small shop that does everything and lots of times we get a Blazer (pre-Trailblazer) or S10 pickup in every day. Those IMO are the absolute worst vehicles GM has recently made. We've got a few customers with TB's that seem to be MUCH better vehicles and I haven't had to do anything major to one yet. My parents have an 03 with 80k. Other than a tie rod end and a recall or non-working brake lights, it's had no problems. I'd say they're a major improvement over what they replaced.
tseekins
Feb 3, 2011 06:43 PM
Trailblazed
18
Feb 11, 2008 04:16 PM
75BigBlock
16
Oct 11, 2005 08:19 AM
9f1501
May 27, 2004 11:45 PM
