General Automotive Discussion
Wife's Trailblazer!
Old Jul 16, 2008 | 07:21 PM
michaelrob2's Avatar
michaelrob2
Wife's Trailblazer!
I was hoping someone might know what the prob is with our 2003 Trailblazer. I know, we should have never bought a Chevy!
Anyway, today she was going in reverse when it stalled. She started back up and went on. She said it shook the whole way home.
I started it later and its not so much a shake as a heavy vibration. It is coming from the engine and it is most noticeable at idle. I dont think its a broken motor mount because there is no "jump" when I revv the motor. I drove it down the road and did not notice any reduced power.
Any ideas?
Old Jul 16, 2008 | 07:37 PM
dkf's Avatar
dkf
Get it scanned for DTCs. If you don't have a reader you can go to autozone and have the codes checked for free. If theres codes they should point you in the right direction. Sort of sounds like a misfire.
Old Jul 16, 2008 | 07:59 PM
jesterdog's Avatar
jesterdog
Yeah, is the check engine light on? Scan it. If it is a bad mass airflow sensor, try cleaning it before buying a new one.
Old Jul 16, 2008 | 10:42 PM
michaelrob2
Yeah I forgot to mention that the "Check Engine" light was blinking.
Thanks for the info guys!
Old Jul 17, 2008 | 02:22 AM
fbama73's Avatar
fbama73
Hey- you can take heart in one thing- it could be a LOT worse. She could have a Durango.
In four years of ownership, the Durango has given us more electrical problems than our last four Fords put together.
Old Jul 17, 2008 | 12:00 PM
alxsnmr's Avatar
alxsnmr
I would say it is a misfire as well, if not a misfire maybe the Cam Position sensor. You wont know until you pull the codes though. Even then it may not retain the code. I ended up buying a code reader for OBDII systems and use it to scan for codes as I drive. It has helped give me a starting point often enough to justify its cost, especially after paying a bill every time the dealership scans for it on a 2000 maxima.
Old Jul 17, 2008 | 01:15 PM
Boss50's Avatar
Boss50
If the light was consistantly flashing on and off, its an emissions problem....Commonly caused by a severe misfire.
Old Jul 17, 2008 | 02:16 PM
michaelrob2
Guy at Advance told my wife that there is a misfire in cylinder #3.
I guess I'll start with plugs and wires first.
Old Jul 17, 2008 | 02:24 PM
150ford's Avatar
150ford
Stupid trailblazers. A neighbor had all kinds off grief with his. I could go in to detail but I would take up an entire page with his problems. Hope you get it fixed. But hey it has a bowtie on the grill instead off the blue oval. In my experience. If you drive a Chevy expect to be stranded somewhere. With a Ford youll make it home without problems.
Old Jul 17, 2008 | 03:55 PM
skaterbro's Avatar
skaterbro
Not too familiar with chebby's, but i'm guessing distributor-less. Might want to test the coil, if new plugs and wires don't do it.
Also, do some searching online. It seems there was a service bulletin for Trailblazers. Something to do with leaking intake valves. You're not alone on the #3 misfire, as it may seem.
Old Jul 17, 2008 | 06:42 PM
TMF's Avatar
TMF
Probably one of the coil packs - when one goes bad, it runs exactly as you describe. (The Ford's do it too...neighbors Expedition just went through 3 coil packs. Each time we diagnosed and repaired one, another would go - 3 in total.) He just traded it (for $2300!) for an '06 F150 Crew cab. Expedition was a '99 w/10x miles on it.
Old Jul 17, 2008 | 08:33 PM
MintFord's Avatar
MintFord
Boss 50 is right, the only thing that will make the check engine light flash is a severe misfire. That means that the engine is misfiring bad enough to damage the catalytic converter(s). It would be best to avoid driving it at all until repaired. Its not hard to diagnose once you narrow down which cylinder(s) is misfiring. I'd lose the Trailblazer, they're nothing but trouble.... weak transmissions, crappy expensive instrument clusters, squeeky suspension bushings, a front differential inside the oil pan.... etc Not that the new explorers with their independent rear suspension, and lousy Jaguar transmission are much better, hehe.
Old Jul 17, 2008 | 09:09 PM
Moore558's Avatar
Moore558
I've done my fair share of work on trailblazers at work. The 4.2L motor uses coil on plug that is similar to the COP on a ford mod motor. The coils are kinda buried under the upper intake tube and silencer assembly. There are 2 10mm bolts that you have to remove that are on the right side of the box (standing in front of the truck looking at the engine). Take those two off and the intake hose off and it will lift up. There you will see the coil packs which are held in by one 10mm bolt each. Remove the connector and lift the entire coil out.
Now since your TB is a 2003 there is something I want you to look at. If the coil boot is orange or like a white chalky substance then water has gotten into that coil and possibly others. This stems from the hood to body seal right above the intake. GM has an updated seal that raises the center part section that allows water to travel around the intake and away from the coils.
This would be my starting point as this was a common problem up until about 05 or so. That should be enough to get you started and hope it helps.
Old Jul 17, 2008 | 11:02 PM
michaelrob2
Wow, thanks for all the great responses. I should have taken a look today but I was tied up with my radius arm bushing replacement.
The guy at Advance said #3 cylinder. Does that mean 3rd from the front or 3rd in firing order?
Old Jul 18, 2008 | 12:00 AM
Moore558's Avatar
Moore558
3rd from front.
