Offroad & 4x4
Front Bumper
Old Jul 14, 2008 | 02:42 PM
ibleedblue1385's Avatar
ibleedblue1385
Front Bumper
Decided it was time to start building a front bumper for yeller'
Aftre a couple hours i knocked this out. When finished it will site an inch or two higher, and i still need to fill in the ends for a smooth look. Planning on putting a reciever hitch in the middle.
Old Jul 14, 2008 | 03:00 PM
BradyCouchman's Avatar
BradyCouchman
Looking good! will look even better a bit higher like you said...
Old Jul 14, 2008 | 03:04 PM
ibleedblue1385
Yeah.
I figured might as well add two D-rings as well.
Old Jul 14, 2008 | 03:06 PM
BradyCouchman
what are you going to use the reciver hitch for? just another pull location?
Old Jul 14, 2008 | 03:07 PM
ibleedblue1385
Yes
Old Jul 14, 2008 | 04:16 PM
STGFordCrazy04's Avatar
STGFordCrazy04
it sits a little to far from away from the truck for my taste but looks great otherwise.
Old Jul 14, 2008 | 05:13 PM
BradyCouchman
yeah...i agree but i was thinking that alot of it would be taken up when it moves up...might not look so far away...
Old Jul 14, 2008 | 05:49 PM
Tre-E_Ford's Avatar
Tre-E_Ford
Did you use C-channel
Old Jul 14, 2008 | 05:59 PM
ibleedblue1385
Yes.
Its as close to the truck as i can get it, without modin' the frame ends.
Old Jul 14, 2008 | 06:01 PM
Tre-E_Ford's Avatar
Tre-E_Ford
you could add some plate ends so it looks like its tucked in closer to the truck
Old Jul 14, 2008 | 06:04 PM
ibleedblue1385
what do you mean by that?
the ends are now plated/closed.
just got done doing that and welding on the brackets. i will have more pics tomorrow after i weld on some d rings and reciever.
Old Jul 14, 2008 | 06:07 PM
Tre-E_Ford's Avatar
Tre-E_Ford
hard to tell by the pics, but if so the plate would extend past the width of the c channel towards the body but if its already done nevermind i think it looks good
Old Jul 14, 2008 | 06:10 PM
ibleedblue1385
Ok i see what your saying. No it does not go "past" the c channel just flush with it.
Good idea though.
I'd say there is about 1/2" if that gap between the bumper and fenders where it will be located.
Old Jul 14, 2008 | 06:19 PM
STGFordCrazy04
it also might be a odd angle pic that makes it seem really far away from the truck.
What size C channel is that? It looks plenty beef.
Old Jul 14, 2008 | 06:20 PM
STGFordCrazy04
did you V knotch the channel on the flanges then bend it in and weld up the seam?
