Offroad & 4x4
Front Bumper
Old Jul 16, 2008 | 04:12 PM
  #76
captain p4's Avatar
captain p4
Originally Posted by STGFordCrazy04
if you put a K&N on top of the vent tube it will give the front axle more horsepower.
Paul had amazing results from putting a K&N on the intake side of his OBA. Im pretty sure it gave his compressor 3-4 more horsepower and another 1mpg.
did you ever finish my minions research project?
true story.
was that research project question directed at me?
If so .
Unless you're talking about measuring axles (which I completely forgot about until right then), but I done sold all of them but a 10.25 and d60.
Old Jul 16, 2008 | 04:19 PM
  #77
ibleedblue1385's Avatar
ibleedblue1385
I searched briefly, but how and theeee hell am i suppost to find one post? Like finding a needle in a hay stack.
And yes i v-notched it, heated it up glowing red, and bent it.
Old Jul 16, 2008 | 04:29 PM
  #78
ibleedblue1385
Working on my back bumper now by the way. And i've been thinking...
I wanted to do a reciever in the back as well. But i want my license plate centered in the bumper. So im stuck...and suggestions?
Old Jul 16, 2008 | 04:32 PM
  #79
BradyCouchman's Avatar
BradyCouchman
you could put the plate on a hinge, or and this would be to much work to be woth it but you could put the plate over the reciver and cut the quare out and put a spring behind it so when you want your reciver you just push part of your plate into the reciver....or just mount the plate on the tailgate or under the bumper again on a hinge (with a spring to hold it down when on the road but will let it swing away when needed)
Old Jul 16, 2008 | 04:34 PM
  #80
captain p4's Avatar
captain p4
What he said.
Either put it on a hinge (like the old kind that had gas fill things behind them) or mount it on the side of the bumper
Old Jul 16, 2008 | 04:35 PM
  #81
ibleedblue1385
mmmmmm interesting. i will need to sleep on this one.
Old Jul 16, 2008 | 04:36 PM
  #82
BradyCouchman
you could get a custom plate (does your state do those?) with no letters or numbers in the center and then just cut a hole in the plate....not very legal but would work
Old Jul 16, 2008 | 05:36 PM
  #83
ibleedblue1385
How about i just do the simple back bumper, license plate in the middle, (2) d-rings on the ends(like the front) and just get a regular hitch for the truck?
Thats what i'm leaning towards.
Old Jul 16, 2008 | 05:42 PM
  #84
BradyCouchman
that would work, and the best idea i heard
Old Jul 16, 2008 | 05:58 PM
  #85
ghunt's Avatar
ghunt
I'm sure a real hitch would be a lot stronger than a receiver tube welded in the middle of a bumper anyway.
Old Jul 16, 2008 | 06:38 PM
  #86
STGFordCrazy04's Avatar
STGFordCrazy04
I like
option 1: receiver tube in the center of the bumper with a license plate holder to slip in the tube. The down side to this is having to remove the license plate anytime you wanted to tow something. Obviously a major no no on the highway.
like this: Hiddend Hitch License Plate Adapter for 2" Receiver - Quadratec
option B: put the receiver under the bumper and not in the center of it. Gusset it from the sides and back. You could also tie it in to the frame mounts.
- my choice.
Old Jul 16, 2008 | 06:49 PM
  #87
ibleedblue1385
Gonna go with option B.
I'll have pics in a couple of minutes...
Old Jul 16, 2008 | 06:59 PM
  #88
ibleedblue1385
License plate mount.
Add to add an inch or so to bottom. Probably going to go with a reciever mounted at bottom of bumper. Plus (2) d-rings.
Old Jul 16, 2008 | 08:16 PM
  #89
MBBFord's Avatar
MBBFord
Looking good!
Old Jul 17, 2008 | 09:34 AM
  #90
BradyCouchman
are you going to put a light on it?
