Sponsored by: Auxito
Accessory stays on
Old Jul 13, 2008 | 07:26 PM
jprindle's Avatar
jprindle
Accessory stays on
I have a 97 F150 that has been sitting for a few months because I am driving my car. When I went to move it today, the battery was dead. I hooked up my booster pack, and the radio came on and the door chime was going off as if the key was in, even though it was not. I was able to start the truck and drive it, but when I shut it off, the radio stayed on.
I have changed the ignition switch, thinking that was the problem, but I still have the same problem. The radio and windows are still operational, even with the truck off and key removed. When I open the door, I get the chime like the key is in. I have also pulled every relay out of the fuse box and under the hood, nothing makes a difference.
It seems like the accessory function is on all the time. Any ideas? I have searched to no avail...
Thanks!
James
Old Jul 13, 2008 | 08:33 PM
steve(ill)'s Avatar
steve(ill)
couple different options, but i wonder if you have a water leak in the front windshield above the steering wheel? is the floor wet? there is a computer box below the dash in this area. if the window leaks it is known to short out a few wires and "things" will go whack-i. another way to do it would be to have the igniton swith (not the key) short out. i think that is what you have changed already (switch?)
Old Sep 17, 2008 | 08:48 PM
jprindle's Avatar
jprindle
I have changes the fuse block, GEM, and ignition switch, and still have the same problem.
Anybody have any ideas? This is starting to drive me crazy...
Old Sep 17, 2008 | 10:51 PM
Wilber15's Avatar
Wilber15
accessory delay relay sticking on? Get a wiring schematic and trace down the ignition system...
Old Jul 25, 2009 | 06:06 AM
richardliebert's Avatar
richardliebert
I am having the exact same problem. Did you ever resolve this in your 97. Mine is a 98. FWIW my problem started the moment I installed a new drivers side mirror. I can't imagine the two issues are related, but the timing was perfect. Test the new mirror, it works, remove the key, and the radio stayed on.
sgrol
6.7L Power Stroke Diesel
May 12, 2014 02:40 PM
tmitchell5188
Jul 29, 2008 09:03 PM
scummings62
Apr 13, 2008 12:58 AM
truckalpers
1997 - 2003 F150
Nov 2, 2005 03:00 PM
5pointslow
2004 - 2008 F150
26
Oct 21, 2004 02:16 PM
