odometer display lights intermittantly
Old 07-12-2008, 08:57 AM
dartguy699's Avatar
dartguy699
dartguy699 is offline
i have an 02 explorer xlt and the odometer will show sometimes and sometimes you can hardly see it. does this have a replaceable bulb or is this a defective led module? i would like to repair it but do not want to replace the cluster. any advice will be appreciated. thanks!
jim
Old 07-14-2008, 11:00 AM
EXPLORER GUY's Avatar
EXPLORER GUY
EXPLORER GUY is offline
I have the same problem,some days it is nice and bright and the other time you can hardly see anything.
Old 07-16-2008, 10:35 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Is the odometer on those trucks digital? If so, pull the cluster and look where the odometer attaches to the board and see if there is a cold solder joint. This has been a problem on the Expeditions and F-150s and it is caused by a cold solder joint.
Old 07-16-2008, 10:25 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
this is the fix for the F150. i did it 3 years ago and worked well. my 02 EXP has not had that problme, i thought it was only the F series.
https://www.ford-trucks.com/forums/1...lem-fixed.html
Old 07-18-2008, 08:41 AM
dartguy699's Avatar
dartguy699
thanks!
i guess the cluster will have to come out to repair it so i know what i will be doing on my next off day!!
jim
Old 07-21-2008, 11:04 AM
EXPLORER GUY
Well my seems to be working fine for now.I started to remove the cluster,everything was going fine but there was one tiny wire i couldn't figure how to remove so i took the screws off the back and pop the electrical board out,with the board in hand the bulbs facing away from me i found three cold solders on the left hand side i put a little bit of solder on it.It is bright now.
ghostdog
1997 - 2003 F150
04-28-2015 06:30 AM
Kaizer88
1983 - 2012 Ranger & B-Series
07-13-2012 12:58 PM
byron2003
2004 - 2008 F150
19
09-05-2011 12:31 PM
Highheat18
2009 - 2014 F150
03-13-2009 02:33 PM
JeffGray
1997-2006 Expedition & Navigator
09-04-2003 11:08 PM
Quick Reply: odometer display lights intermittantly
