Play along at home with a new game:" What was Henry Thinking?"
Try to identify the what style of drive this bolt that attaches my driveshaft to the differential:[/IMG]
My solution was to beat a 1/2" socket onto it with a BFH and I'll probably do the same when reinstalling it and then ask Mr. Sears or Mr. Roebuck, "Please, sir, may I have another?"
12 pt metric was what I used on an A*star drive shaft. Same head design used on the Lima 2.3 cylinder head bolts. Don't they have 12 pts where you live?
Ah, Cleveburg, the mistake by the lake. Loved it and the Emerald Necklace. The parties in the park on Fridays were well attended by NavFinCen when I was stationed there. Is the Coast Guard still there at the foot of E 9th?
tom
Thanks for the information. You gotta cut me some slack on these things: I'm college educated. Yes, the Coast Guard is still at the foot of 9th st. Tom, but you'd hardly recognize that area now: yuppie-fied and Captain Frank's is long gone. I still maintain "What was Henry Thinking?" would make a good game.
my 86 Bronco had those for the drive shaft.. only smaller.. had to use a 12 pt. 5/16 or 8MM. when I first saw them, I was like "what the $%^ are those??"
No, external spline drive has flats just like a driveshaft spline. This is a 12pt bolt.
That's right. 12pt bolts allow better torque distribution from the driver to the bolt. I picked up the proper socket to remove the bolts at Sears when I lubed my driveshaft spline. I believe these bolts are high strength steel so if you replace them make sure the equivalent is used.
haven't came across those yet but when I was rebuilding my mitsubishi I bought a large set of craftsman with 6 and 12 point metric and standard for about $150.00 so I was covered all the way around. plus a set of those t-star sockets for brakes and a few other odds and ends and have about everything I need. if I come across something to wierd its off to a mechanic I go, I hate working on new cars.
i sort of hate those little bugers... had a heck of a time finding the 12 points we KNOW we owns.... ended up with a clean[er] garage before the drive lines where installed on the navjo..
