idle speed
Old Jul 10, 2008 | 10:03 AM
dogbreath1000's Avatar
dogbreath1000
idle speed
what should my 65 240 idle at?after i fixed the carb gasket and some air leaks and set the points it idles almost a grand...is this too much?
Old Jul 10, 2008 | 10:14 AM
Redmanbob's Avatar
Redmanbob
You need a vac gauge/timing light if you want to get this correct. Happy reading How to Use and Interpret a Vacuum Gauge
or you could just wing it. I'd at least read the plugs if your going to wing it. White in color means lean which if you cannot get the idle down with throttle stop I would suspect yet another leak and or timing is off.
I'm an FE guy but suspect the idle is similar. 650rpm in gear (park brake on wheels chocked) safety first
Old Jul 10, 2008 | 12:09 PM
dogbreath1000
idle
is it the same for a standard trans as an automatic????
Old Jul 10, 2008 | 06:49 PM
matt2491's Avatar
matt2491
Engines backed by standard transmissions generally have a lower idle RPM than do those with automatics. My 292 y-block w/ 3spd standard idles at 500rpm.
Old Jul 10, 2008 | 09:26 PM
Redmanbob's Avatar
Redmanbob
sorry I didnt look into your user CP and you didnt mention that part.. not sure on the rpm diff based on std/auto.. will have to assume matt is correct. Seems odd as the Auto out of gear would obviously have "higher rpm" but no idea.. I'd buy a manual for your truck myself.. money well spent.
Old Jul 10, 2008 | 09:56 PM
billy12360's Avatar
billy12360
it should be ideling at 500 on either a manual or automatic
according to chiltons truck repair 1961-1971
manual says 500
automatic says 500D[im not sure what the d stands for... drive maybe?]
shortbed97
Jan 29, 2012 11:40 AM
cperdue3
1978 - 1996 Big Bronco
May 24, 2005 02:18 AM
Vampiro
Oct 17, 2002 10:34 AM
Fnord
Sep 20, 2002 09:44 PM
Blue coyote
Bronco II
Jul 31, 2001 11:36 PM
