1978 - 1996 Big Bronco
Idle drops when first cranked???
Old May 23, 2005 | 11:06 AM
cperdue3's Avatar
cperdue3
Idle drops when first cranked, then idles back up before stalling... Any ideas?
Old May 23, 2005 | 01:26 PM
BillyBob69's Avatar
BillyBob69
What year, engine? If new enough, could very likely be the IAC. (Idle Air Control valve).
Old May 23, 2005 | 02:07 PM
cperdue3's Avatar
cperdue3
Thanks!
This is on a 1992 XLT, with a 302, auto, 81k miles - other than the drop in idle when first cranked, it idles and runs extremely smooth.
Old May 23, 2005 | 02:15 PM
greystreak92's Avatar
greystreak92
Sounds like a dirty or malfunctioning IAC as Billybob mentioned. Best thing to do is to see if there are any codes stored in the computer. I can only assume that the CEL (check engine light) comes on when it dies. There should be some indication in the computer codes as the the source of the problem. If you have a Haynes manual the procedure for pulling the codes is there. If not check www.fordfuelinjection.com. This will eliminate a lot of guesswork when trying to troubleshoot the problem.
Old May 23, 2005 | 02:30 PM
cperdue3's Avatar
cperdue3
greystreak92,
It never actually dies, the rpm's drop real low(like it's going to die), but then they pick back up and it idles fine.
Could I have the codes read at AutoZone on my '92?
Old May 24, 2005 | 02:18 AM
greystreak92
AFAIK yes, you can. If not, all you really need to pull them yourself is a paperclip. A Haynes manual will deliniate the procedure from there.
jayvee208
1997 - 2003 F150
Jun 12, 2016 01:51 PM
Ordnance
Mar 25, 2014 05:14 PM
69 lil' Red Shane
Jan 24, 2014 10:31 AM
tHeCoS
Nov 8, 2004 07:57 AM
Black Ford XLT
Jul 29, 2004 09:48 AM
