Ranger trans swap info
94 Ranger, 4.0L, 5sp.
VIN: 1FTCR10X2RUC38962
What trans is in it and from what year range trucks can I get a suitable replacement?
Thanks.
Thanks.
Probably the Mazda built 5 speed. I think the Mitsubishi ones were older models. Check pics here. You can probably shop from several years of the Ranger.
Domestic Truck Tranny Guide
Note there are two models-- Ranger size & F150 size, you need the Ranger model and they are not interchangeable.
Good luck.
Or you could find a 2005+ V6 Mustang that's been stuffed into the wall and get the entire set up out of it. A Tremec of some type, not sure of model number, better shifting, but of course, you'll have to reach out the back window to shift, or move the shifter.... Just a random not-so-helpful thought.....
Good luck.
you didnt say if the truck was 4x4 or not but you can go here Car-Part.com--Used Auto Parts Market to see what years fit if its 4x4 you could also get one out of an older explorer
redwings
03-13-2005 09:04 PM
