Sponsored by: Real Truck
KeyPad Lock Question
Old Jul 8, 2008 | 09:24 PM
trick76cj5's Avatar
trick76cj5
I just bought a used 08 SuperDuty, now I got a question. I've never had the Keypad entry option before. In the owners manual it talks about the factory code being on a card in the glove box. . .as luck would have it, that is missing. It also said the code would be printed on the computer. Any idea of which computer, and were the computer would be found so I can program my keypad?
Old Jul 9, 2008 | 09:11 AM
caprang's Avatar
caprang
Welcome to FTE!!!
Hopefully you will get a more informative answer from another member here. I havent looked under my 08 yet but on past vehicles the computer you are looking for is either under the dash or behind a kick panel. It will be a 5 digit code. The other option is to contact the original dealer. Most (but not all) dealers will record the code on their copy of the invoice (along with the key codes) so they can retrieve that info pretty easily. If you dont know the originating dealer you can request an OASIS report through this website. See the tech section for details.
Good luck, enjoy your new ride.
Old Jul 9, 2008 | 10:05 AM
redford's Avatar
redford
FTE Leadership Emeritus
A dealer can also plug a scanner into yout computer and read the code, although most will charge you for this. If you purcahsed the truck at a Ford dealership you might be able to talk your salesman into giving you a freebie scan.
Old Jul 9, 2008 | 10:08 AM
supeRobertduty's Avatar
supeRobertduty
The Keypad is gone for 2009 model
Old Jul 9, 2008 | 10:23 AM
redford's Avatar
redford
Wow, no keypad on the '09?
Old Jul 9, 2008 | 10:26 AM
Brian0445's Avatar
Brian0445
my keypad code was on a plastic card about the size of a credit card in my owners manual packet.
Old Jul 9, 2008 | 11:18 AM
trick76cj5's Avatar
trick76cj5
Thanks for the feedback guys, i'll call the dealership i got the truck from and see if they have it documented somewhere.
Old Jul 9, 2008 | 11:50 AM
supeRobertduty
Yes,
IT's outdated :
Why is it outdated ? , But I love mine and use it all the time !
FORD and Insurance companys did a lot of research :
If you lock or leave your keys in the ignition , Someone breaks in and drives away !
People forget the numbers all the time
Sharing of cars means sharing of number's and they forget also
Cost
Failure rate: Wireless was replaced by hard wired a few years ago to help, but cost is now more of a issue.
It gave customers a False sence of security
So Whats coming :
A on star type remote un-lock
proximity key fob (keyless) and alarm
Dumb in down and Idiot proof it they said
Old Jul 9, 2008 | 08:33 PM
aldridgec's Avatar
aldridgec
I'm questioning this information about the keypad.
It states wireless went to wired but cost became an issue???
When were they wireless?
They've been wired for 20 years or more haven't they? I thought so. They were around before they wireless keyfobs.
Wireless was an after-factory option provided because of the popularity of the option, works as a key fob on the wireless keyless entry module. Wired units were still from the factory, at least up to 04.
Old Jul 9, 2008 | 08:52 PM
80351's Avatar
80351
Yes,
IT's outdated :
Cost
So Whats coming :
Sorry for the Hi jack just wanted to know if you planned on going to Carlisle or visiting the chapter?
Old Jul 9, 2008 | 08:55 PM
trick76cj5's Avatar
trick76cj5
thanks for the input guys, called the dealer . . . low and behold, they had the code. The keypad is now up and running!
Old Jul 9, 2008 | 10:50 PM
unrulee's Avatar
unrulee
I didn't think that I'd use the one on my truck when I bought it, now I use it all of the time.
On a side note, wether anyone knows this or not (a buddy told me) if you push the last two numbers at the same time the doors will lock, handy.
Old Jul 9, 2008 | 11:38 PM
supeRobertduty
When the Key pad first showed up on the superduty it was stick on and wireless to the module in dash . In 2005 It went to a Hard wired design with mounting holes in the door and Wires to the module.
Old Jul 10, 2008 | 01:28 AM
the cleaner's Avatar
the cleaner
Can a new # be reprogrammed into the keypad on the 08 model ?
Old Jul 10, 2008 | 10:09 AM
Beerstalker's Avatar
Beerstalker
Yes all keypads can be programmed to accept a different number. The instructions are in the locks and security section of your owner's guide.
