compressor not running
Old Jul 1, 2002 | 06:43 PM
kpoly2's Avatar
kpoly2
Post compressor not running
1994 Bronco. Compressor won't run and it seems to have enough freon in system. Someone mentioned a pressure switch and it might be bad. Any ideas on what to do before I have to take it to the service station. Thanks.
Kpoly2
Old Jul 2, 2002 | 08:17 PM
topo4u2's Avatar
topo4u2
Are you sure there is enough freon? and how do you know? That is usually the first reason for the compressor to stop running. There is a low pressure cutoff switch in the line up near the evaporator which you can bypass and see if compressor turns on. You may have a fuse gone as well. I have also seen the dash switches go bad to and can cause your problem..good luck.
Old Jul 3, 2002 | 07:57 PM
TheWiz427's Avatar
TheWiz427
FuzzFace2
Nov 3, 2019 09:26 AM
renchr56
1997 - 2003 F150
Oct 23, 2015 07:09 PM
reaydanny
1997 - 2003 F150
Jul 16, 2012 05:37 AM
kpoly2
Jul 27, 2006 09:15 AM
kpoly2
Jul 8, 2002 10:14 PM
