Hard Start after Partial rebuild
Old Jul 7, 2008 | 08:22 AM
fluidp's Avatar
fluidp
Hard to start after insalling engine. It cranks for 3 or 4 seconds then starts and idols fine.
I had the engine out for a rod and piston replacement. I also pulled the heads for inspection and replaced the injector seals.
Insalled engine and cranked it over and blead out air at my high preasure X over. After the air was out it started after it cranked for several sec. After letting it idol for 15 min I shut it down, topped off the oil and started again, same thing , took 3 -4 sec. of crank before it started.
????????????????? Anyone have any suggestions, Thanks
Old Jul 7, 2008 | 09:29 AM
tjbeggs's Avatar
tjbeggs
I just has some more air in the HPOP system and that is very normal. Once your get the truck out on the road and run it for 20-50 miles it will clear up.
Old Jul 7, 2008 | 09:57 AM
fluidp's Avatar
fluidp
Thanks Tim. I guess I screwed up when I put my pan on with permatex, because the dam thing is leaking at the rear. I should have used the rightsealant. I am getting good at pulling this heavy chunk of iron out, ha ha
Old Jul 7, 2008 | 02:01 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Read the post below named: oil pan gasket
Old Jul 7, 2008 | 09:16 PM
RubberDuck's Avatar
RubberDuck
Also the permitex will remove the anti-foaming agents from the oil....Bad. That's another reason for the special RTV.
nick13
Modular V8 (4.6L, 5.4L)
Jan 13, 2016 11:05 AM
Rusty Axlerod
Jan 9, 2016 05:44 PM
domifan
Nov 10, 2015 08:36 AM
86trouble
25
Apr 10, 2014 06:34 PM
paintballpro650
Dec 9, 2013 03:28 PM
