oil pan gasket
Old Feb 16, 2008 | 11:30 AM
Smokin&Strokin's Avatar
Smokin&Strokin
Question oil pan gasket
How big of a pain is it to change the oil pan gasket on a 95 PSD and does anyone have a how to for dummies? My mechanical ability is good, but this is my first diesel. Thank everyone for their help...this site is great!!!
Old Feb 16, 2008 | 12:47 PM
84-250's Avatar
84-250
Its not a gasket, its RTV. Also, you have to remove the engine, flip engine over to get best results. I've heard of guys cutting/removing the crossmember under the engine to remove the oil pan. Are you sure its the oil pan gasket? Can you live with it? Oil is a good rust preventative
Old Feb 17, 2008 | 09:07 PM
mastertech2002's Avatar
mastertech2002
Bummer I really do know your pain... some helpfull hints from expirence you wanna do it right ? you gotta pull the motor and not to jump right to the end but make sure you only use motorcraft atv for sealent for the job... any other brand could cause the oil to foam and cost you an engine ...
Old Feb 17, 2008 | 10:17 PM
c00nhunterjoe's Avatar
c00nhunterjoe
not just motorcraft rtv, it must be ford motorcraft 7.3 diesel silicone. anything else wont seal
Old Feb 17, 2008 | 10:23 PM
MTNWOODY's Avatar
MTNWOODY
How'd they manage that? An oil pan that will use only THE magic "ford motorcraft 7.3 diesel silicone?"...WTF?
- Ish
Old Feb 17, 2008 | 10:26 PM
c00nhunterjoe
i'm sure you can get an equivialant aftermarket, but i gurantee you that if you play with the diesel silicone you will use it on everything, its thick and isnt affected by oil. it is so adhesive when dry that it will actually peel up concrete if you smear it on a clean piece. when you try to get the pan off your motor you have to use a hammer and chisel to break it loose. it really is good stuff
Old Feb 18, 2008 | 06:03 AM
Smokin&Strokin
Thanks for the info guys...I really appreciate it.
Old Jul 7, 2008 | 08:50 AM
fluidp's Avatar
fluidp
Now I find this thread!!! Out comes the F!@#$%ing motor again!!!!
bizzelj
Apr 12, 2015 06:20 AM
Bigal700
May 9, 2014 11:49 AM
caclark1992
Dec 4, 2011 11:18 AM
oldcoupe42
34
Jul 7, 2010 08:10 PM
kerim1
Nov 2, 2009 08:42 PM
