CCV Mod, Done!!
Old Jan 15, 2009 | 11:15 AM
Izzy351's Avatar
Izzy351
Yep -- mine's up over the brake booster, too. Never had a drip from the end of the hose in nearly two years. Mine runs to the rear axle by the exhaust, so no noticeable smells at all. I do see a little cloud coming out of the passenger wheel well area sometimes. Tells me it's doing its job...
Old Jan 15, 2009 | 12:02 PM
DieselBeast01's Avatar
DieselBeast01
Anybody got any pictures of that wastegate delete mod. I would like to do it. Good job Mike on the CCV you will really like it.
Old Jan 15, 2009 | 12:39 PM
superduty4x4's Avatar
superduty4x4
Nothing to see really, just no more red line going to the wastegate and a shorter actuator rod.
Old Jan 15, 2009 | 01:10 PM
Izzy351's Avatar
Izzy351
I just disconnected mine and plugged on the the I/C boot clamp's threaded rod right there by the spider. Made a noticeable difference. Just watch for surge! Mine surged with the stock wheel badly when I did that. WW fixed it, but it's all moot now -- van turbo has no wastegate, and with the stock wheel & ATS housing, it ROCKS!!
Old Jan 15, 2009 | 01:28 PM
DemonRace6's Avatar
DemonRace6
Hi!
What will happen when it surges? Whats WW that fixed it? I just finished plowing some driveways, time for some free mods! I'll take pics of the wastegate mod now, hopefully I will be back soon
Old Jan 15, 2009 | 02:00 PM
triskit16's Avatar
triskit16
Only time I see any smoke from mine is when Ive been idling. Ive even had a few folks at a rest area run to me and tell me my truck was smoking a little from under the cab. When I idle and go in reverse I can see the actual smoke, but otherwise I cant really see any from the cab. I dont think the smell is all that bad, but maybe Im just weird.
Old Jan 15, 2009 | 02:19 PM
DemonRace6's Avatar
DemonRace6
Hi!
I assume I spin this around and plug the hole in the intake?
I am going to do the wastegate mod now as well but...
My gauge pod just came in! Thats why im back in the house, going to be a fun day!
Old Jan 15, 2009 | 02:36 PM
Ponyboychris's Avatar
Ponyboychris
Yes. I've read that there are some o-rings to make sure that they are in good shape and don't fall out of the doghouse.
Is that an under the dash type of gauge pod?
Old Jan 15, 2009 | 05:04 PM
jdecker88's Avatar
jdecker88
Looking good Mike, I thought you painted your IC tubes.
Old Jan 15, 2009 | 05:37 PM
big poppa's Avatar
big poppa
I,m dieing to see if you put the WW in there, the whistle is sweet!
Sent you a link from Guzzles home page, all the info you need, great guy. Instead of plugging that little hole, take that piece off and i can send you a piece of 4 inch SS pipe to put in there, let me know, it will look and work better.
They are painted JD, this thread was from July of last year, but i am a procrastinator though, haha.
Old Jan 15, 2009 | 09:34 PM
DemonRace6's Avatar
DemonRace6
Hi!
Thank you! That would be awesome! I just pluged up the hole for now and ran the hose down near my driverside rear wheel. I will make the trap for it when I can.
The gauges came out nice though, need paint and one more gauge!
Old Jan 15, 2009 | 09:41 PM
DemonRace6's Avatar
DemonRace6
Hi!
I tried to get the wastegate off but gave up after working on her all day, where is this pin that I have to be carefull of flying off?
Old Jan 15, 2009 | 09:48 PM
  #28
Izzy351's Avatar
Izzy351
///SNIP///
I doubt I'm going to now. The way it's working right now, I don't need it. There's "enough" whistle in there for me the way it is. It's already bugging the wife & daughter, so I imagine the WW will really be obnoxious. LMAO!! Besides, I'm interested in BOOSHT not, whistle. Well, MORE interested in boost anyway.
Old Feb 1, 2009 | 04:35 PM
  #29
DemonRace6's Avatar
DemonRace6
Hi!
My CCV mod is totally done thanks to big poppa pump sending me the pipe piece!
Old Feb 1, 2009 | 05:27 PM
  #30
big poppa's Avatar
big poppa
Glad i could help Joe, my pleasure on the pipe. Just seen your gauges in here, looks good, what ones did you get???
