92 Ford E250 Vacuum Drop
Old Jun 5, 2002 | 03:06 PM
kenyk's Avatar
kenyk
Everytime I put a power demand on the engine my climate control system stops working. In the case of air directed through the vents the air stops blowing. I assume it stops because the damper for the climate control shuts, in effect the system is going into the 'off' mode. I suspect that there is a vacuume drop which allows the damper to close. Further more I assume there is a check value somewhere in the system to prevent reverse flow of vacuume for the heater/ac control. Anyone have an idea as to what is causing this and where it is located. Once I let off the accelerator all function returns to normal.
Old Jul 24, 2002 | 04:15 PM
scottyscheff's Avatar
scottyscheff
[updated:LAST EDITED ON 24-Jul-02 AT 05:16 PM (EST)]I had this problem in my 92 F-150. I finally found a bad vacuum hose. Under the hood, on the passenger side, above the blower motor, and next to the firewall is a vacuum pump. The vacuum hose that connects to that pump was shot. It looked fine on top, but the bottom was shot.
A simple way to check is to try moving the valve on the pump. It should offer resistance. Mine just flopped back and forth.
Hope this helps.
Old Jul 25, 2002 | 03:15 AM
Scotty1's Avatar
Scotty1
Macs1964F100
Jun 14, 2014 08:17 PM
miker67
Sep 11, 2009 10:04 AM
howlincold
Dec 16, 2008 09:48 PM
Saxon
Jun 1, 2007 06:53 AM
mmiller7461
Jan 27, 2007 08:14 PM
