Sponsored by: Real Truck
Another vacuum problem....
Old Jan 27, 2007 | 10:51 AM
mmiller7461's Avatar
mmiller7461
Question Another vacuum problem....
Hey what's up everyone...
I hate that my first post has to be one asking for help but I'm desperate. First of all sorry for the lengthof this post but I figue the more info the better. I have an '01 F250 with a diesel motor and my climate control and 4 wheel drive are not working properly. My climate control is stuck on defrost, but when I turn my 4 wheel drive on, after about 30 seconds my climate control will function normally for about a minute and then it will go back to defrost. I know the vac pump is running all the time. I checked what was happening underhood and found that the vacuum switch valve was clicking when the 4wd switch was turned allowing vac to pass to the climate control. I would assume that vacuum is supposed to go to the climate control all the time. The next time the vacuum switch valve clicked the line to the climate control lost vacuum. I am a mechanic and am pretty confident in my ability to figure out this problem but I don't know how the system is supposed ot function normally which makes it kind of difficult to troubleshoot. Any insight you might have would be great. Thanks in advance.........
Old Jan 27, 2007 | 11:13 AM
MTMike's Avatar
MTMike
Welcome!
I would check the vacuum lines to your hubs - assuming you have the ESOF (electronic Shift on the Fly).
mike in montana
Old Jan 27, 2007 | 08:14 PM
mmiller7461
Thanks for the reply Mike....
I have already checked those lines they all hold vacuum and the hubs actuate when a vacuum is pulled on them.
Jarhead_Top_P
Aug 28, 2013 03:36 PM
jeem
Jun 28, 2013 06:40 PM
Bauer44
2004 - 2008 F150
Nov 16, 2009 01:33 PM
sleek122
Jul 30, 2008 02:05 PM
cfrives3
1978 - 1996 Big Bronco
Dec 30, 2007 01:31 PM
