How does damper work in AC system?
Old May 26, 2007 | 06:08 AM
Saxon's Avatar
Saxon
How do I check the damper in the duct to see if it is in the heat mode?
This may be the problem why my AC is blowing hot air?
I guess when I switch the controls the damper should open or close?
Old May 26, 2007 | 09:57 AM
subford's Avatar
subford
This damper you are talking about is cable controlled and you should be able feel and maybe hear the damper go from open to close when you move the lever from cold to hot and back again.
Some times you will have pencils or something blocking the full movement. They drop down from the top of the dash in the vent openings.
Old May 27, 2007 | 04:41 AM
fmr9's Avatar
fmr9
Only real good way to check that damper is to pull the cover off the heater core. The damper and any foreign object is readily accessable and visible . Take the glove box out first, then about 8 small screws. Just a 5 minute job to pull the cover and take a look.
Good luck Frank
Old Jun 1, 2007 | 05:47 AM
Saxon's Avatar
Saxon
Would the damper be functioning properly if when in 'Vent' mode, not AC, the air being blown out goes from hot to cool with movement of the temp control ****?
Does this verify damper door operation or does it still need to be verified while in AC mode?
I have been wanting to pull the heater core cover and check but have not got to it yet and just wondering if the vent & AC modes work the same or different.
Thanks
Old Jun 1, 2007 | 06:33 AM
subford's Avatar
subford
Yes that is what it does.
Yes that will verify damper door operation.
Thanks
It works the same.
Here is a diagram:
http://i54.photobucket.com/albums/g9...em/AirFlow.gif
Old Jun 1, 2007 | 06:53 AM
fmr9's Avatar
fmr9
If the damper has something in it, that prevents it closing completely, it will still go from hot to cool but not as cold as possible. Doesn't take a lot of hot air to bring up the output air temp. Mine had a deck screw wedged in the door. This prevented the door from closing completely. I've heard of doors having pens, kids toys, crayons, nails, etc. Pretty common problem, and really easy to check.
Good luck Frank
Effin-Yeti
Sep 26, 2014 11:39 PM
pholmes350
Jul 28, 2014 09:28 PM
mackda600
Feb 10, 2010 05:08 AM
FordF150Fixer
4 Cylinder Engines
Jul 24, 2004 06:58 PM
bronco93@Miami
1978 - 1996 Big Bronco
20
Aug 29, 2003 03:22 PM
