Heater Control Valve
Is there a valve that controls the flow of coolant to the heater core? I am trying to flush the cooling system and I cannot get water to flow through the core. The Temp control is to heat. I left it there yesterday while driving but had the blower and dash control off when the truck was shut off. I started the truck today with the air control to "Floor" and the blower on. It still does not allow water through.If there is a heater control valve, can it be manually opened? I saw a schematic of the vacuum lines on another post and it looks like damper doors control the temp.
Unhook the hoses from the front side, mop up the spilled coolant and just pull the core out, into the cab. 1/2 hour replacement, easy.
Sounds like the same procedure then. I wish all heater cores were that easy. I had an '86 Volvo 760 once. Nice car, but it was built around the heater core.
I'll have to take your word on that one, I never even see Eagles anymore. Kind of surprising though, they were a very popular vehicle in their day.
From what I understand my Volvo was a PITA because the 760's were climate control. The 740 would have been a typical job from what I was told.
That new core was $$$$ too!
To the OP - try removing both hoses right at the heater core, and then hooking a short piece of hose up to the inlet and connect a garden hose to it, see if that direct pressure does anything. If not, put the hose on the _outlet_, so as to backward flush it. If that gets it, then you have some contaminant in your coolant and a filter may be in order. If not, yeah, it's new core time.
On a 64 the heater control valve is on the passenger side inner fender, Make sure the heater hoses are installed correctly from the water pump or it won't work.
Heater cores for 64 is an orphan part, when they (were) available they were almost 300 bucks or something stupid like that. They can be repaired by a radiator shop.
My apologies on providing incomplete information. The truck in question is a 94 7.3 n/a. My other truck is a 64 with a 292 and I was able to flush all kinds of brown stuff from its heater core. This one must be plugged bad.
Now I know there is not valve I will put 15 or 20 lb of air pressure on it to see if that loosens it up. If not I will pull the core and work on it or replace it. The coolant I have retrieved so far has been clean, real clean. The engine is running hot so the PO may have flushed the system trying to solve the issue. I am going to do a 3 day chemical flush and want the heater core to be flushed at the same time.
I am going to Ford and get a new thermostat in the morning. I live in South Texas and it will be getting hot soon. I want the cooling systems to be in good shape, including the little used heater.
