Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
No topic thread,,, Part 2
Old Aug 14, 2015 | 06:29 PM
  #23581
Jigger2020's Avatar
Jigger2020
Thats right M, a good trans shop wont over chage us,
Grant theres probably an Oring on the output shaft, did the yoke you have come in the same car?? it should quit leaking before long
like this
Old Aug 14, 2015 | 07:09 PM
  #23582
yamagrant's Avatar
yamagrant
It's the same yoke that came with the car. I had it out for a while, and the tailshaft bagged. I'll let it be for now. I'll put some grease on the splines in the yoke and try it out. Thanks for your help Gerry.
Old Aug 14, 2015 | 07:10 PM
  #23583
56panelford's Avatar
56panelford
Howdy guys.
Old Aug 14, 2015 | 08:12 PM
  #23584
Jigger2020's Avatar
Jigger2020
I agree Grant, just keep an eye on it, like you said
Old Aug 15, 2015 | 07:41 AM
  #23585
96sherm's Avatar
96sherm
Morning boys. Some rain and a T-storm rolling through this am. Supposed to be a warm one again today, then dropping quite a bit for tomorrow.
Went to the dealer yesterday to look for an economical vehicle for back and forth to town when I don't need to be driving a truck. While there they asked if I was interested in a project. They have a 2008 F150 Lariat with a nasty sounding motor. They valued it at 3g when a guy was trading it in. I'm tempted to get it and find a motor for it. Shouldn't be too hard to find a 5.4L with lower kms. The rest of the truck has 200k on it which isn't too bad. Going to go look at it closer today, probably take it for a drive and see if the trans/transfer case/4x4 seems fine, maybe look into getting it.
Have a great day guys!!!
Old Aug 15, 2015 | 07:45 AM
  #23586
Jigger2020's Avatar
Jigger2020
Shake your head Sherm, do you really need that problem......
Old Aug 15, 2015 | 09:50 AM
  #23587
yamagrant's Avatar
yamagrant
Happy Saturday mornin'all. Man was it hot yesterday! I didn't have any air movement in the garage, and couldn't get much done. Today looks about the same. Sherm: Correct me if I'm wrong, But aren't those truck's a bugger to pull the engine. I think you have to remove all the front sheetmetal to get the motor out. It sits too deep into the cab. Have a great day guy's. stay cool.
Old Aug 15, 2015 | 12:37 PM
  #23588
96sherm's Avatar
96sherm
You're right guys. I don't need the headache and the expenses. That's the end of that.
Old Aug 15, 2015 | 07:02 PM
  #23589
yamagrant's Avatar
yamagrant
Taking the night off. 2 evening's of hot, humid no air movement in the garage. I put on hose's, belt's, shifter linkage, Tranny shift lever, Gas pedal. loctited my frt engine accessory brackets and cleaned and installed the top engine harness:Name:  004.JPG
Old Aug 15, 2015 | 07:17 PM
  #23590
56panelford
Looking good Grant, are you using an electric fan? Is that a stock power steering pump? I need to get myself one.
Hot here too and we are under a tornado warning here also
Old Aug 15, 2015 | 07:20 PM
  #23591
56panelford
I was told you need to lift the cab
Old Aug 15, 2015 | 07:31 PM
  #23592
yamagrant's Avatar
yamagrant
Yes John. I'll need an electric fan. my fan will sit too low, and block off the tranny cooler ports. The P/S pump is the original. I think you need the newer model pump. it has metric fitting's matching the rack ports. It's opaque in colour (info courtesy of a Mustang forum). As for the engine removal.I know of a guy who has it down to a science by pulling the frt sheet metal off and pulling them out forward. He just does diesel's, but I think they both come out the same.
Old Aug 15, 2015 | 07:35 PM
  #23593
56panelford
What year pump should I be looking for, this motor I have has V- pulleys I suppose the pulley on the pump I have would fit the newer type?
Old Aug 15, 2015 | 07:44 PM
  #23594
yamagrant's Avatar
yamagrant
You should be safe with the 90 newer. As for fitment, I believe they all Have the same hub size, so your v-belt pulley shroud press on. you also could use the old saginaw styled pump. Bracketry and fittings are very popular. Going for a quick shower.
Old Aug 15, 2015 | 07:50 PM
  #23595
56panelford
And here I was thinking it was me...LOL I better go and spend some time with Frances seeing as it is her birthday and all. TTYL
