Smoke Problems
Old Jul 18, 2008 | 01:46 AM
  #61
ccg711's Avatar
ccg711
bump.
any ideas
Chad
Old Jul 18, 2008 | 06:21 AM
  #62
F350-6's Avatar
F350-6
Sorry. My high speed has been giving me problems. Like you mentioned the night shots are difficult to get a good reading on, but if the blow by is as bad as it looks in the first vid, that's when the recommend a rebuild. Of course there's a chance the flashlight might be making it look a lot worse than it is. Any chance of getting some daytime shots?
Old Mar 20, 2011 | 09:42 AM
  #63
BIG FORD FAN's Avatar
BIG FORD FAN
Old Mar 20, 2011 | 09:58 AM
  #64
BIG FORD FAN
ITS A BLOWN PISTON IN LIKELY #5 FROM A BAD INJECTOR THAT LED TO THE SMALL HOLE THAT CAUSED THE SMOKE AND SOME LOST POWER THEN THE BIG BANG WAS THE LOADING OF FUEL VAPOR IN THE CRANKCASE THAT WAS SET OFF WHEN ENOUGH OXYGEN WAS ENTERED IN THE BLOCK OR EXHAUST CAUSING FUEL IN OIL AND EXCESS OIL IN EXHAUST THEN THE SMOKE COMING OUT THE OIL FILL IS COMING OUT FROM THE PISTON HOLE IN TO THE CRANKCASE BLOCK . A COMPRESSION TEST WOULD HAVE HELPED
Yama4fitty
Jan 20, 2017 09:54 PM
Lead Head
Jul 1, 2016 12:54 AM
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
sms2323
Aug 24, 2014 05:42 AM
creator
25
Feb 5, 2012 07:21 PM
