1978 - 1996 Big Bronco
79 Bronco Automatic Kickdown & Throttle Linkage
Old Jun 26, 2008 | 08:44 PM
79FordBlake's Avatar
79FordBlake
Unhappy 79 Bronco Automatic Kickdown & Throttle Linkage
Anybody have pics of how the trans-automatic kickdown should be set and adjusted? 79 Bronco, 351M, still factory style two-barrel. The linkage is hooked up but the spring is gone. I would like to get it hooked up and adjusted and working properly incase some speedster trys to run me over and I can't shift down a gear to get rpms up to move outta the way.
I have a friend that has a pickup with a 351m and it has an adjustable throttle linkage. My Bronco has a throttle cable that is to long and the pedal is almost on the floor. Where do I find a linkage or shorter cable?
Old Jun 27, 2008 | 03:29 PM
ranger429's Avatar
ranger429
Try bending the gas pedal rod that the cable is attached to. You will have to take the pedal assembly out but it can be done. The kickdown rod does not use a spring. It mounts on a post that is attached to the carb. There is a small screw that is used to adjust when you want the kickdown to start to operate, adjust that.
Old Jun 27, 2008 | 10:04 PM
79FordBlake
What steps do I need to take to adjust the kickdown? I think your supposed to adjust it with the throttle held in full open position then adjust so there is a certain distance between the screw and throttle plate. Im not exactly sure though.
telmoff
Jun 12, 2022 09:19 AM
Chris79F350
Nov 4, 2015 07:12 PM
52' fordnut
Mar 13, 2013 05:44 AM
hozee4
May 19, 2008 04:09 AM
N7ghtwolf
Sep 14, 2007 10:21 AM
