1978 - 1996 Big Bronco
93 Rag Joint Replacement
Old Jun 19, 2008 | 02:56 PM
93Mule's Avatar
93Mule
I'm getting ready to replace the rag joint on my 93 but I'm not 100% sure how to get the old one off. I searched around and I think that there are some rivets holding the old one on that need to be cut off, then the new one bolts on. Is this correct?
Old Jun 20, 2008 | 10:41 AM
sowder's Avatar
sowder
I got a kit at NAPA for my 79, had to grind 2 rivets then bolt everything together it was all in the kit. Cost around 13 bucks. get the kit first then you can see what you have to do.
Old Jun 20, 2008 | 09:01 PM
McLeod's Avatar
McLeod
I thought that 93's had u-joints in the shaft with no rag joint.
Old Jun 21, 2008 | 11:06 AM
b4hntn's Avatar
b4hntn
My 94 rag joint is in great shape. If you are chasing steering slack be sure it is not the gear box.
Old Jun 23, 2008 | 09:53 AM
93Mule's Avatar
93Mule
I was thinking that. I have replaced the box before but it was with a used unit. I'm having front end noises right now. I think it might be the steering box or axle pivot bushigs, or a combination of both...
Old Jun 23, 2008 | 10:00 AM
b4hntn's Avatar
b4hntn
Be sure the three bolts through the frame into the steering box are tight. Loose ones cause popping noises when turning.
Old Jun 23, 2008 | 10:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There is no separate rag joint available for Bronco's from Ford.
It's part of and sold as part of the steering shaft & coupling assembly only.
Old Jun 28, 2008 | 07:22 AM
93Mule's Avatar
93Mule
**Update**
I laid under the truck this morning while my son turned the wheel form side to side. I found out that my radius arm bushings are making my front end noise. I'm off to advance to get some replacements.....
tiredone
20
Mar 8, 2017 07:27 PM
badasssapper67
Feb 21, 2017 09:44 PM
Buildingdavej
Aug 31, 2016 08:15 PM
shorerider16
18
Jul 22, 2016 06:48 PM
vidaliaman
May 4, 2016 07:59 AM
