Help Lokar Kickdown
Old May 20, 2006 | 09:02 AM
telmoff's Avatar
telmoff
Cool Help Lokar Kickdown
Trying to install lokar kickdown cable on c4 trans. and holley 4bbl carb. Problem is the lever on the carb is on top over the top of the throttle linkage and made to push to engage. The cable instructions show the kickdown linkage under the throttle linkage and pulling the cable to engage. What is the fix? I'm stuck and about ready to go back to the old rod kickdown.
Thanks
telmoff
Old May 20, 2006 | 12:16 PM
ivanribic's Avatar
ivanribic
Don't know if your throttle linkage is set up the same as mine but here is what I did on my old Holley carb for the kickdown. You can see the grey Lokar mount at the bottom of the linkage so as the throttle opens all the way it activates the kickdown.
Old Jun 12, 2022 | 09:19 AM
armyaviation's Avatar
armyaviation
Sam boat here. And clue how to use the Lokar cable with a Holley 600 to C4
The Ogres master
Jan 11, 2018 02:19 PM
mustang_gt_350
Jul 6, 2010 02:45 PM
cudaz101
Jan 30, 2006 10:36 AM
bulldogcountry1
Jan 3, 2003 01:51 AM
bigal72
Aug 20, 2002 07:01 PM
