proper timing specs
Old Jun 26, 2008 | 08:03 PM
j tate's Avatar
j tate
proper timing specs
i have a lumi probe timing meter and was wondering what the timing was supposed to be set at. my truck is a 92 with the 7.3.
Old Jun 26, 2008 | 10:12 PM
Dave Sponaugle's Avatar
Dave Sponaugle
About .5 ATDC with the luminosity probe.
Old Jun 27, 2008 | 05:13 AM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
Question, To time these, do you need both the luminosity probe (i guess thats what goes in the glowplug hole) and the pulse injector sensor? Or do you just use one or the other and if so which method is better? Thanks
Old Jun 27, 2008 | 07:30 AM
PLC7.3's Avatar
PLC7.3
Normally the 7.3 was timed by the Pulse method only........
DieselDon's info
If you have the original emission label on your valve covers, they gave the max pump fuel flow rate in mm3 at rated HP.
As I recall 6.9 was about 48mm3 sea level and 44mm3 for high altitude pump
7.3NA was about 54mm3 and 49mm3 for high altitude
7.3 IDI Turbo - 58 mm3 ( this is out of the Ford book )
Optimum timing: 6.9IDI ( Ford method ): .5-1.5 degrees ATDC
6.9IDI ( Navistar method ): 6-7 degrees BTDC
7.3 NA: 8-9 degree BTDC*
7.3 IDI Turbo: 8-9 degrees BTDC*
Anything above these, the engine get's pretty noisey.
* helps engine starting. Original timing was 5-6 BTDC and engine cranked a long time ( at least in comparison to 6.9 ) before starting.
Old Jun 27, 2008 | 09:01 PM
j tate's Avatar
j tate
ok i have a dumb question about the timing meter that i have. i havent really used it since i bought it and its kind of a learning experience for me. when you turn the meter on to see what the timing is set at, you can turn the pump one way and it will read like -1.5 and the other way it will read like just 1.5. which way is atdc and wich way is btdc? another question is, is the 8-9 degrees for luminosity probe or pulse method?
Old Jun 27, 2008 | 09:07 PM
Dave Sponaugle
8 degrees is pulse method.
Since the pulse method senses the fuel on the way to the injector, it has to be sooner.
With the luminosity probe, you see the ignition event happen.
Timing is the same, just a different method setting it.
Not seeing your meter my guess is the minus reading is BTDC.
Old Jun 27, 2008 | 09:40 PM
j tate's Avatar
j tate
my meter is a lumy/mag ll, snap-on MT 1480. ok since the timing is to be set at 0.5 atdc, is the off set the same as the 6.9 for the #1 cylender as the 7.3 (20) and what rpm do you set it at? thanks dave for the info you have been alot of help since i bought my first truck.
Old Jun 27, 2008 | 09:52 PM
George D.'s Avatar
George D.
What kinda fancy dangled witch craft is this? I work at an IH dealer and had to time a 6.9 recenly the guys that rebuilt the engine put the timing gear in 180 out and couldn't figure why it was smoking. All the old timers seemed to think using a luminasity probe ot a tach'n'time or any other light was a waste of time and some said that they hardly worked. So I timed it by sound smoke and how it ran. I mention this just to let you know if after using one of these timing devices if you truck doesn't run right there probly isn't a problem with it you may just have to play with the timing a bit. Also these trucks have a two pice balance wich can throw the readings off.
Good luck to you all.
dirty trucker
1983 - 2012 Ranger & B-Series
Sep 12, 2012 07:01 PM
BrettCox
17
Jan 6, 2003 09:25 AM
SPROCKET
Nov 11, 2002 06:18 PM
Varnish
Jun 25, 2002 02:52 PM
beratte
1978 - 1996 Big Bronco
Feb 15, 2002 02:14 AM
