RF Filter
Old Jun 21, 2008 | 01:25 AM
Dodge/Cummins's Avatar
Dodge/Cummins
RF Filter
I need an RF filter in my IDI.
The radio frequency interference is pretty bad some times and not as bad others. You can even hear it on CDs sometimes. The DVD player is useless if the engine is running.
What's wrong with this thing? This is the one part of 12V electrical systems I know nothing about. I hate dealing with sound systems.
Is it something else?
If I need a filter what type/brand/style is the best?
Help me stereo guys!
Old Jun 21, 2008 | 02:04 AM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
It is probably alternator noise. It could have a bad rectifyer (a diode) in it. They make some little filters for them. If you get the right capcitor, you can shunt the ac signal (noise) out of the 12v system to ground, or use a RF filter transformer wired so that it works against itself to cancel the ac noise. Some audio stores ACTUALLY have someone there that would probably know what you need to fix it.
Old Jun 21, 2008 | 02:53 AM
Dodge/Cummins
I figure it almost HAS to be alternator and I'll need a filter for it. If that's so I want to do it right.
Old Jun 21, 2008 | 05:49 AM
stevilknevil's Avatar
stevilknevil
does it do it with the motor off?
Old Jun 21, 2008 | 10:36 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Check the capacitor mounted on the voltage regulator.
I have seen several that were corroded so bad the wire was disconnected.
Radio Shack has a large pass through capacitor that will filter out alternator, wiper and heater motor interferance.
Right now I can't remember the value, but the sales people will know what you need.
Any decent stereo shop should have the same parts.
Old Jun 21, 2008 | 11:42 AM
tbone91's Avatar
tbone91
Probably alternator. If so, it should follow engine RPM. One other wild guess would be an electric fuel pump, if you've added one.
Since DVD players weren't stock, how is it wired in (both power and ground)?
I bet if you went to the dealer, they'd try to sell you "resistor plug wires"
Old Jun 21, 2008 | 01:00 PM
George D.'s Avatar
George D.
Alternator is the only thing it could be, unless you MOPAR nuts have found a way to add spark plugs to an IDI. Your diode trio is probly bad. Take a DMM put it on AC volts and go from positive to negitive if you have more than 1.5v your diodes are bad.
Old Jun 21, 2008 | 11:40 PM
Dodge/Cummins
The electric fuel pump is not wired up yet so that's not it. I'm sure it's the alternator and it does follow the rpms. I'll have to check the diodes, if they're bad I need to change them out anyway.
I needed the info on the filter. Thanks.
I don't know how the DVD's wired up. But it is useless with the motor running right now.
Old Jun 21, 2008 | 11:52 PM
George D.'s Avatar
George D.
As far as I know you shouldn't need a filter if your alternator is working properly atleast as far as the cd player is concerned no too sure on that DVD player you got in your aperant pimp ride.
Old Jun 22, 2008 | 12:15 AM
Dodge/Cummins
We MOPAR guys didn't figure out how to put spark plugs in a diesel, we didn't even put GLOW plugs in a diesel.
Old Jun 22, 2008 | 12:22 AM
FORD MEGA CAB!!!
Well, at work againg, we have some 6bt (i think they are bt but I know they are cummins diesel engines) cummins with ignition packs and plugs in them that run on CNG that have a maximum rang of less than 100 miles on 2 tanks bigger than me and have no power.
Old Jun 22, 2008 | 12:39 AM
Dodge/Cummins
I've never heard of a Cummins with anything but a grid pre-heater in the intake but they were put in all kinds of equipment so I'm not gonna say they're ALL that way. If it's a 359 C.I.D. Cummins burning that muck fuel with no power it must be pulling the Space Shuttle to it's launch site all by itself! Something sounds fishy, maybe Compressed Natutral Gas is extremely inefficient.
Old Jun 22, 2008 | 01:46 AM
FORD MEGA CAB!!!
It is inefficient but i guess it burns cleaner. Im sure hardly anyone uses it. We have some older ups trucks that had the converted cummins. Im sure its not a conversion made by cummins though. They mainly use it just for around town deliveries and we have probably 35 cng package delivery trucks and about 6 are cummins. They must not have a conversion for the 7.3 idi or Im sure we would be using them as well. and we have probably 50 or so of them.
Old Jun 26, 2008 | 03:19 PM
Dodge/Cummins
Put new alternator on, saved the old one for spare. Same noise, time to get an RF filter.
Old Jun 26, 2008 | 05:25 PM
tbone91's Avatar
tbone91
What about the capacitor on the voltage regulator? Did you find it? Is it hooked up? I'd replace it first before bothering with a filter.
I know it's a pain, but make sure your power and ground connections are done right. The unit might be grounded through the antenna lead or to the dashboard, or powered from some place strange...
