Sponsored by: Auxito
Radiator Leaking
Old Jun 26, 2008 | 03:04 PM
Pinaylariat's Avatar
Pinaylariat
Radiator Leaking
I plan to replace my leaking radiator with a new one from the local Napa store. I've never done this so can anyone advise? Any special tools or precautions? Oh yeah - 1999 F150 Lariat w/4.6L. The dealership service advisor sees $$ opportunities whenever a female has a problem with her vehicle so I thought I could save alot if I could do it myself. Thanks...
Old Jun 26, 2008 | 03:23 PM
KingRanchMan02's Avatar
KingRanchMan02
Hello Pinaylariat and welcome to FTE! This job should not be too difficult. Statndard tools and your time to drain the cooling system, then R&R the radiator. You should replace the coolant while you are at it. Good luck!
Old Jun 26, 2008 | 05:45 PM
Lance1601's Avatar
Lance1601
Got a friend that can help?
Old Jun 26, 2008 | 07:06 PM
galaxie641's Avatar
galaxie641
Flare nut wrenches for the tranny cooler lines, if you have them, are about the only special tools. The rad. simply unbolts at the top and then pull straight up, there are two pegs on the bottom that hold it in place. Be ready for a shock when NAPA gives you the price for a new one. IIRC they run $300+.
I almost forgot since I have Efans I never think about the clutch fan, you will need to rent the clutch fan removal tool from autozone. To get around buying flare nut wrenches you can use a good crescent wrench, get it on the fitting nice and tight so it won't round the corners.
BTW, is the leak at the side were the tanks mount to the core?
Old Jun 26, 2008 | 07:20 PM
sheetsd66's Avatar
sheetsd66
Why does she need a clutch fan removal tool?
Old Jun 26, 2008 | 08:17 PM
steve(ill)'s Avatar
steve(ill)
depending on the overall condition of the radiator and where the leak is at, i would be temped to get a bottle of BARS radiator sealer and pour it in the tank and call it good.
Old Jun 26, 2008 | 08:27 PM
sheetsd66's Avatar
sheetsd66
Don't go there, steve. We don't want anybody broke on the side of the road in the middle of the night. She's better off fixing it herself the right way. Next thing, somebody's going to tell her to dump black pepper or egg whites in there to stop it up. It's an aluminum radiator core with composite tanks and o-rings- replace it and drive on.
Old Jun 26, 2008 | 09:35 PM
galaxie641's Avatar
galaxie641
Simply for ease. Nothing like dropping a new radiator in and spearing it with your fan. It has been a few years since I replaced my rad. and even longer since I had a fan but I wouldn't want it and the shroud rattling around in there while I was trying to replace the radiator. I have done it on 460's and it is a major PITA.
Old Jul 28, 2008 | 10:17 PM
beast51's Avatar
beast51
Changing radiators
I have replaced mine 3x now. I have a 99 5.4L Supercab. You shouldn't need to pull the fan. Remove the fan shroud and let it lay back against the engine, over the fan. Remove the the upper and lower hose clamps and detach hoses. (The lower hose clamp was somewhat a pain, but just because an akward angle.) Unbolt radiator supports at top that hold in place.
The fittings for the transmission lines should come out easy. When you put them back in, make sure you start them by hand, since you don't want to cross thread them.
Old Jul 29, 2008 | 02:23 AM
bamafordguy97's Avatar
bamafordguy97
I have a leaking radiator myself. Well did have one. BUT I didnt have the $$ @ this time to buy and new one and thats not really something I wanted to go junk yarding for. I have never been a fan of that stop leak crap but it done the job and tied me over until a better money situation came around. Just my personal opinion. I would replace the radiator if it was in your money plans but if not the stuff works for a short term fix. Just follow the instructions. It all depends on your personal budget.
I already had plans to replace it anyway just wanted the one I had to make it a little longer.
Old Jul 29, 2008 | 02:49 AM
ford390gashog's Avatar
ford390gashog
The radiator should be this one Proliance Ready Rad 431383 - Proliance Ready-Rad Radiators - summitracing.com summit has the best prices on them.
Old Jul 29, 2008 | 07:03 PM
AzBlueWolf's Avatar
AzBlueWolf
if you are worried about nicking the radiator with the fan, place a piece of cardboard in front of the fan until the radiator is in
cut a piece from the box the radiator came in!
Old Jul 30, 2008 | 03:57 AM
ford390gashog
I always use the box the rad came in ,cut 2 pieces of cardboard and cover both sides of the radiator. This prevents any damage and MODINE even requires it on all new installs.
1964Goat
Mar 21, 2012 07:34 PM
mblanken881
Mar 7, 2012 02:34 PM
FordOwnerJoey
Feb 27, 2012 11:03 PM
rebelmdb
17
Sep 7, 2010 12:25 PM
dzwiss
Jul 29, 2010 05:41 PM
