Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
1978 ford
Old Jul 18, 2008 | 08:28 PM
  #61
preppypyro's Avatar
preppypyro
Hell man you should make a 4x4 dune buggy of some sort!
Old Jul 18, 2008 | 08:46 PM
  #62
Fomoko1's Avatar
Fomoko1
What shape is the rest of the Bronco? A Bronco 11 or is it full sized?
Old Jul 18, 2008 | 08:55 PM
  #63
77f-250HB's Avatar
77f-250HB
fullsized.
rest fo the bronc is pretty rusty.
from what i am told has a 400 that runs a little rough(owner thinks its the choke) backed by an auto. most likely the C6.
the transfercase i would probably end up keeping unless someone was interested in it.
axles are the D44 front with the 9" rear, and what i assume is the ever so common 4:10 gear ratio.
he also said its a "camper special" but i never knew they offered a bronco in that platform
Old Jul 18, 2008 | 09:03 PM
  #64
preppypyro's Avatar
preppypyro
Too bad its rusty. I liked them old broncos, thats a cool find marshall, even if you found it just for the rims!
Old Jul 19, 2008 | 12:48 AM
  #65
Dustin1690's Avatar
Dustin1690
Cool find nonetheless those 79 Broncos are sweet rigs
Old Jul 19, 2008 | 01:24 AM
  #66
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Bronco ID's.
Originally Posted by 77f-250HB
fullsized.
The 4th digit of the VIN is the engine code: 1978/79 Bronco: H = 351M 2V / S = 400 2V.
Transmission is a C6.
The same Styled Steel (SS) & Styled Aluminum (SA) wheels used on Bronco's were introduced on the 1977 F100/150's.
1977 was the first year Ford offered SS or SA wheels on trucks. The very first use of SS wheels was on 1965 Mustangs.
The AXLE code is on the Warranty Plate, located on the left door face below the latch.
If a letter is the first digit of the code, it has Limited Slip (LS). If a number, no LS.
With Limited Slip: H2 (3.50-1) / H3 (2.75-1) / H4 (3.25-1) / H9 (4.10-1)
Without LS: 06 or 13 (2.75-1) / 12 or 14 (12: 1978 ~ 3.00-1) / 12 (1979 ~ 4.10-1) / 15 (3.25-1) / 16 (3.50-1).
Note: Some Bronco's have a 3 digit AXLE code, if so...the third digit decodes to the front axle. The 3rd digit may decode to the ratio, it may just decode to Power Steering.
There was no such thing as a Bronco Camper Special ever, but there was a Trailer Special offered 1978/79. The Trailer Special emblem is on the tailgate, if so equipped.
Morris: Bronco II's introduced 1984.
Old Jul 19, 2008 | 08:14 AM
  #67
preppypyro's Avatar
preppypyro
I didnt know there was a trailer special, thats very neat, what did they include with that package? I assume a second battery as one thing...
Old Jul 19, 2008 | 08:34 AM
  #68
NumberDummy
Originally Posted by preppypyro
I didnt know there was a trailer special, thats very neat,what did they include with that package?
I was afraid you were gonna ask that!
You assume correctly.
1973/79 F350 Trailer Special / 1976/79 E350 (Econoline) Trailer Special / 1978/79 Bronco Trailer Special.
Some of the standard equipment:
Front/Rear Stabilizer Bars / Super Cooling Radiator / Heavy Duty Frame (exc Bronco & Econoline) / Trailer Wiring Harness / C6 / Western Mirrors on 1973/74's only / Camper Style Mirrors 1975/79 / 55 Amp Alternator / 70 Amp Battery / Oil & Amp Gauges / Auxillary 70 amp Battery / Step Bumper / Inside Hood Release / 32 Gallon Fuel Tank w/Skid Plate (Bronco only) / Trailer Special Emblem.
Old Jul 19, 2008 | 02:00 PM
  #69
66gpw's Avatar
66gpw
Those axle codes were great. But you did not mention any Dana axles codes. My 78 has a rear dana axle. So curious what it is.
Old Jul 19, 2008 | 03:41 PM
  #70
NumberDummy
Those are all the rear axle codes listed for 1978/79 Bronco's in the parts catalog.
Are you sure your Bronco has a Dana rear axle?
If so, I'm also curious what it is...so post the AXLE code from the Warranty Plate.
Dana axles have an inspection cover, the Ford 9 inch does not.
Old Jul 19, 2008 | 04:31 PM
  #71
66gpw's Avatar
66gpw
Sorry the dana is on my 3/4 ton truck. Not a Bronco. Just curious to id the different Dana rear axl;es. Had a fella selling one and did not know it and what size it was in a truck he had. He wants to know. I never saw the axle. but he gave me the numbers a while back to let him know. So I was wondering what the numbers were for the dana's?
Old Jul 19, 2008 | 05:00 PM
  #72
NumberDummy
Sorry the dana is on my 3/4 ton truck. Not a Bronco. Just curious to id the different Dana rear axl;es. Had a fella selling one and did not know it and what size it was in a truck he had. He wants to know. I never saw the axle. but he gave me the numbers a while back to let him know (What are they?)
You tell me...I listed the Bronco's cuz that was a piece of cake.
1973/79 Bronco's are listed in the 1973/79 Passenger Car Parts Catalog, the rear axle codes are all listed on one page.
That's not the case with F Series trucks. There are pages of codes.
In order to list all the Dana's codes, that'll take an hour minimum.
1973/79: F250: Dana 60; Dana 61-1 / F350: Dana 70
The AXLE code is listed on the Warranty Plate.
The Dana: 60, 61 & 70 rear axle ID tag is on a 2" x 1/2" metal plate bolted (2 bolts) to the axle just to the left of the inspection cover (right side on 60 front axles).
The ID code will by 7 digits similar to this: 603010-1.
There are over 100 7 digit number codes listed in the parts catalog. Some are for 44's, some are for 60's, 61-1's & 70's.
Post either the AXLE code off the door, or the 7 digit ID code off the rear axle, it'll take less than 2 minutes to decode and post the info.
If you want just the axle ratios for Dana 60's, that's a piece of cake, too.
Off the cuff: 3.31-1 / 3.54-1 / 3.73-1 / 4.11-1 / 4.56-1.
RENA1608
25
Oct 13, 2016 03:45 AM
Mmann84
2009 - 2014 F150
May 9, 2016 04:15 PM
PSD2005
Nov 20, 2010 03:32 PM
99PREDATOR
Feb 22, 2010 11:52 PM
78 4X4 Thunder
Garage & Workshop
13
Apr 4, 2003 09:26 PM
