1996 with a rough idle
Old Jun 23, 2008 | 08:00 PM
Justin Time's Avatar
Justin Time
I have a 1996 with a rough idle. To me when I am standing by the exhaust it pops like a gasoline engine with a burnt valve. Normal? Runs out strong and gets 20 mpg when I drive with my big toe and not my big fat foot! But it idles rough.
Thanks,
Justin
Old Jun 24, 2008 | 04:04 AM
Cuda_jim's Avatar
Cuda_jim
Is the check engine light on?
Might want to Have it scanned anyway.
How old is the engine oil. These engines are very touchy about oil level and quality.
If it's getting close to 'Oil Change Time' then do it.
Same goes for fuel filter.
Old Jun 24, 2008 | 07:32 AM
Justin Time
Thanks Jim, 2000 miles on my oil change but mostly in town. Fuel filter last week and air filter onmy list for today. i will try the oil and air before a $100 scann.
Thanks
Old Jun 24, 2008 | 07:52 AM
Action4478's Avatar
Action4478
Try unplugging the ICP connector ,,,see if it smoothes out ...
Old Jun 24, 2008 | 10:50 AM
Justin Time
Disconnected the battery, waited a few and reconnected ........smooth idle returned. Well, smooth for a 7.4!
Thanks,
Justin
Old Jun 24, 2008 | 11:26 AM
Cuda_jim's Avatar
Cuda_jim
That's great, hopefully it won't return. Sometimes the PCM is just confused.
BTW: Try pulling #22 & #9 fuses under the hood to reset the PCM.
Doesn't always work but it's an easy to do.
7.4 ?? Your engine has grown by .1 L
Sorry had to do it
You can get it scanned a some Autozones for free.
Old Jul 4, 2008 | 03:52 PM
Justin Time
Rough idle continues but only when it warms up. Smooth as a pair of silk panty hose when cold but lopes when it gets warm. Sounds like it's running on 7 1/2 cyl until you get it out on the road then it smooths right out. Anything above 1200 RPM runs smooth.
New air filter, oil change has 1,000 miles on it. Fuel filter has about the same as the oil.
Ideas?
Thanks,
Justin
Old Jul 4, 2008 | 05:31 PM
WALJON's Avatar
WALJON
Hi Justin just curios have you changed your injector o rings? or are they original just wondering because my 96 is in need of injector o rings and mine does exactly what yours is doing even more now since I put in a 203 stat just a suggestion it may not be you problem.
Old Jul 4, 2008 | 07:06 PM
Hussler's Avatar
Hussler
Ideas?
Thanks,
Justin
Here is a great article from Kim Lux on injector inter workings.
Diesel-Central.com the technical source for Diesel Truck information, Truck Pulling, and Drag Racing
I learned a lot reading this but don't know if it's pertaining to your issue. I'm sure my turn is coming.
Old Jul 4, 2008 | 07:27 PM
Butch(OH)'s Avatar
Butch(OH)
My 7 1/2 cylinder problem was slightly different than yours but I had rough idle too. Two things to check. Check your fuel pressure at the schrader valve with a gauge. Mine was doing the bounce routine that comes from a shot fuel pump, thats where my miss was coming from. 2 cycle oil in the fuel has made a real differance in smoothness and noise in mine. Split a quart of outboard oil between your tanks at next fuel up. The results came very quick in mine and I run it all the time now. If it works for you do some shopping and buy it in bulk to save a bunch.
Old Jul 6, 2008 | 12:24 PM
Justin Time
Thanks for all of your help. Going to have her scanned this week to see what if any code comes up then go from there.
Thanks,
Justin
Old Jul 6, 2008 | 10:29 PM
c00nhunterjoe's Avatar
c00nhunterjoe
while getting it scanned ask them to moniter ipr duty cycle cold through warm up. you need to see what the ipr is commanded to, to see if you have an oil leak developing at hot oil temps. could be as simple as an ipr o-ring up to injector o-rings.
mustangnewby
Aug 19, 2014 02:01 PM
Justin Jude Solet
Mar 11, 2014 12:04 AM
ryzl30
Arizona Chapter
Jan 28, 2008 02:41 PM
Justin Time
Nov 29, 2006 10:00 PM
celticrebel
1978 - 1996 Big Bronco
Mar 18, 2004 10:49 AM
