Aerostar Ford Aerostar
Missfire
Old Jun 23, 2008 | 08:23 AM
jetfiremuck's Avatar
jetfiremuck
Missfire
Developed bad missfire with flashing cel light. I think I have bad gas/water in the tank. I had replaced the plugs and wires recently. Pulled codes P0301,P0304 out of it. I did an injector flush and added dry gas and octane booster and ran the van shuddering and all to E on the tank. Put 6gals of fresh gas in and still have that shudder. It is misfiring. Is it possible to have damaged the recent spark plugs under these conditions? I will change the fuel filter today.
Old Jun 23, 2008 | 09:24 AM
Bear River's Avatar
Bear River
Former ******
Ok, what engine. If you have the 4.0L, it uses coil packs, and one coil cylinders # 1 and #4. Test the primary and secondary resistance of the coil, and if it is not in specs, buy a new coil pack.
Old Jun 23, 2008 | 09:36 AM
jetfiremuck
Sorry, 4.0 1997 259k miles. It is still on the original coil pack I will check the coils as you suggested, Thanks
Old Jun 23, 2008 | 01:01 PM
96_4wdr's Avatar
96_4wdr
did the miss start after the plug/wire change?
damaged failed spark plug ignition wire on on one of the series pair spark plugs
what brand were the replacements?
Old Jun 23, 2008 | 01:26 PM
jetfiremuck
No wires are autolite with autolite double plats. Engine ran fine until bad gas introduced I dont have the powertrain manual to test the coil however at $68 at Autozone a replacement coil I just purchased will elimanate the coil pack. Will let you know how it worked out.
Old Jun 23, 2008 | 01:46 PM
96_4wdr's Avatar
96_4wdr
was the gas old, dirty or contaminated with water.
if yes to any above, time to pull injectors and have professionally cleaned, 2 are plugged/gummed up.
coil is not the problem. never seen a Ford EDIS coil pack fail, they're bullet proof except for connector corrosion
Old Jun 23, 2008 | 05:51 PM
jetfiremuck
Yes to all the above . I will put another set of plugs into it. They look pitted on the electrode when i took them out, I had a half tank of bad gas and ran it to the E. I cleaned the injectors with the Napa pressurised injector cleaner at 35psi today.I will have to wait to pull the injectors as I need to do a700 mile round trip this week. The coil I replaced did improve the miss however as you said the old one was probably ok.
Old Jun 23, 2008 | 07:55 PM
96_4wdr's Avatar
96_4wdr
fuel filter is probably plugged and gummed up from the bad gas also
Shell just had a refinery/tank farm problem here. forgot to add the octane additive and cleaner but I'm hearing it was worse than that. they had a pipeline pig fail and mix diesel with gas.
good luck with the miss.
i fought one all winter, finally found the cause this spring.
ClatonK
2004 - 2008 F150
May 31, 2011 10:22 PM
300FOREVER
1983 - 2012 Ranger & B-Series
Jan 31, 2011 08:39 PM
Pablo-UA
Aug 24, 2009 03:08 AM
Glock
1997 - 2003 F150
Feb 27, 2006 09:09 PM
keyul
Modular V8 (4.6L, 5.4L)
Feb 9, 2005 09:51 PM
