Missfire
Old Dec 18, 2010 | 05:06 PM
300FOREVER's Avatar
300FOREVER
Missfire
I have a check engine light on because of a missfire on cylinder #1. I've already changed the plugs and wires. What else should I look at for the cause of the missfire? Coilpacks?
Old Dec 18, 2010 | 05:34 PM
96dangerranger's Avatar
96dangerranger
could be fuel injector and it could be a burned valve. u need to do a compression test.
Old Dec 19, 2010 | 12:01 PM
300FOREVER's Avatar
300FOREVER
Will do,thanks for the tip
Old Dec 27, 2010 | 06:45 PM
96dangerranger
did you every figure anythang out?
Old Jan 10, 2011 | 05:49 PM
NJohnstonMN's Avatar
NJohnstonMN
300FOREVER, what did you figure out? I'm having the same issue.
Old Jan 10, 2011 | 07:47 PM
michigan66's Avatar
michigan66
Year of truck; engine size? What code/codes do you get? If you can't read the codes, go to AutoZone or some other auto parts store and have them get a readout of codes for you and let us know what they are.
Old Jan 11, 2011 | 01:07 PM
mismy68cougar's Avatar
mismy68cougar
I actually had that with my minivan. Soon after the dealer installed new plugs while doing other un-related work started having a misfire. Very random but drove me nuts for several months. Thinking maybe an older plug wire got cracked i replaced all of em. Still happened. Went thru same thought process- injecters, coil pack... Even started thinking torque converter stumble! After a while i said if it feels like a bad plug it must be, but they were new?! Any way since it was the easiest and least costly option I replaced them all again and problem solved. Had to be a faulty new plug that the mechanic probobly dropped on the floor but that was it! Just my 2 cents.
Old Jan 11, 2011 | 04:09 PM
michigan66's Avatar
michigan66
If you are going to replace spark plugs, be sure to use either Motorcraft or AutoLite plugs - double platinum, if you have a 4 cyl. Did you use Motorcraft or AutoLite wires as well, our Ford engines seem to run better with them that with other brands.
Old Jan 31, 2011 | 08:39 PM
300FOREVER's Avatar
300FOREVER
A cheap off brand plug wire was the culprit this time fellas.
S Cesaro
Sep 18, 2012 09:22 AM
50'sFord
1997 - 2003 F150
May 8, 2012 04:13 PM
hearnoevil
2004 - 2008 F150
Dec 28, 2009 09:41 AM
thecarone
Oct 17, 2008 08:08 PM
Bear River
Aerostar
Jun 12, 2005 10:47 AM
