code p0236
Old Jun 21, 2008 | 02:52 PM
shockzone's Avatar
shockzone
code p0236
i just scaned my truck with my edge and i got this code p0236 turbo cir. performance A does anyone have any ideas.
Old Jun 21, 2008 | 03:00 PM
Cuda_jim's Avatar
Cuda_jim
How is it running? If it's down on power you may have a bad MAP sensor or...
Check the MAP sensor rubber line for pin holes or maybe it's just got bumped off.
The MAP sensor is on mounted the fire wall by the AC/heater box and has a 1/4 inch rubber line going to it fron the intake.
Old Jun 21, 2008 | 03:08 PM
shockzone's Avatar
shockzone
it seems to run fine i have a boost gauge and egt boost is 10 psi at 2200 on a hill and 1000 degrees. does that sound correct.
Old Jun 21, 2008 | 04:13 PM
Cuda_jim's Avatar
Cuda_jim
10 psi is low, you should be seeing around double that.
The Edge programmer maybe the reason for the higher than normal EGT's with low boost?
Are your Boost & Egt's on the programmer? or separate gages? The Edge uses a signal
from the MAP to the PCM and interprets it into psi.
If you have a mechanical boost gage be sure to check the line leading to the gage for leaks.
Return the truck to stock, remove the programmer if it's not too hard. See if the code goes away.
Look for boost leaks. Tell me more about your "Homemade intake"
Old Aug 3, 2009 | 10:45 PM
mrp669's Avatar
mrp669
po236 will set if truck doesnt produce at least 13 psi boost. i have same code on stock but if i max my ts chip i get 17 psi. that seems to tell me that it is electrical somehow. i believe all the chip does is change fueling-increase injection timing and pressure. could it be weak hpop or ipr?
VEightFreak24
Mar 7, 2017 11:49 AM
Kelly MT
Jun 6, 2012 06:41 PM
fordpride
23
Jan 26, 2012 08:48 AM
JoshWegener
Aug 26, 2010 10:21 PM
wmiller
22
May 18, 2010 09:22 PM
