boost levels low??
Old Jun 17, 2008 | 03:48 PM
ron's power stroke's Avatar
ron's power stroke
click on this pic..the orange piece in front of the turbo is the spider pipe..you can see the IC pipes and boots going to it..under that there are 2 boots...your are orange..mine are black and you can just see them in there..the oil is normal..that is caused from the tube that you asked about not being hooked up..we have a ccv mod to fi this problem..the ccv mod iis in my mods and fixes link in my sig..
Old Jun 17, 2008 | 03:50 PM
ron's power stroke
Originally Posted by miller_feed
On this pic you will see the orange spieder Ron painted. At the bottom of the two tubes is orange boots that need to be tight also.
Hope you don't mind me using your pic.
lol....posted when i was typing..im slow.lol thats what the pic's are for Rick...
Old Jun 17, 2008 | 03:57 PM
03F2507.3's Avatar
03F2507.3
I took the blue ic boots off the truck. They arent horribly dirty but had to be shimmed off with a flathead. I was careful not to puncture or cut them. Should I clean them with a standard degreaser and reinstall?
Also, the orange boots...just tighten them down?
Old Jun 17, 2008 | 04:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Yeah, clean them them then put them back. I would tighten the orange ones, if it works you are good to go. Always better to take them off an clean. 'But I know they are more work.
Old Jun 17, 2008 | 05:29 PM
03F2507.3's Avatar
03F2507.3
Ok, blue boots cleaned and reinstalled. Foil delete done. Air intake reinstalled. Orange boots tightened. Ran truck and still 10lbs boost. Sounds different with foil gone. But still not enough boost.....
Old Jun 18, 2008 | 04:20 PM
03F2507.3's Avatar
03F2507.3
Can anyone give me more ideas??
I do have a vacuum leak somewhere. The hubs wont always engage and the a/c blows from the defrost vents when 4x4 switch is engaged. I have to manually lock them. Will this cause a boost problem? I dont know if the boost and vacuum system are tied together somehow?
Old Jun 19, 2008 | 08:33 AM
miller_feed
The vacuum system is not part of the boost system. Are you sure your gauge is working right?
Old Jun 19, 2008 | 08:48 PM
03F2507.3's Avatar
03F2507.3
Well, I guess I can get another guage and try it. But I highly doubt its the guage. I might have to brake down and bring it to the shop.
Old Jun 20, 2008 | 03:14 AM
ron's power stroke
did you build a boost leak detector to check for leaks?? this one cost me less then 20 bucks to build..i found i had a leak under the driver side plenum when i tested mine..it would only leak when the boost got around 15 to 20 lb's.....if and when you do it this way..check the line going to the gauge as well..if it leaks and this is pluged in you will hear it..
bduemig
Sep 10, 2013 08:08 PM
Yingling256
Jun 13, 2013 08:08 AM
03slowbra
May 26, 2010 11:43 AM
rtazz17
Oct 17, 2009 08:15 PM
