Mass air flow sensor?
Old Jun 16, 2008 | 10:04 PM
Mydiesel250's Avatar
Mydiesel250
I was looking at my airfilter box and i see the plug in the box and im considering an intake but first is this the mass air flow sensor? and if so do you guys drill a hole for the plug?
Old Jun 16, 2008 | 10:13 PM
superduty4x4's Avatar
superduty4x4
Which thing are you talking about? There are two gizmos in a PSD airbox- a filter minder and an Air Intake Temp (AIH) sensor. No MAF on a diesel. The filter minder is a big plastic doo dad, the AIH is the small "sensor" in the back of the stock airbox near the brake master cylinder.
As far as going to an aftermarket intake- just zipty the AIH out of the way (no effect on performance). The filterminder has to be dealt with differently depending on if yours has the wires going to it or not.
May I suggest as your best choice for an intake the DIY 6637 intake:
Old Jun 16, 2008 | 10:20 PM
rebelchevy02's Avatar
rebelchevy02
Actually, for what its worth, I am almost 100% certain the 6.0s and newer have MAF sensors. However, our 7.3s do not. As you said, the two sensors in our OEM airbox are the air intake temp, and filterminder, to measure restriction.
Old Jun 16, 2008 | 10:29 PM
superduty4x4
6.0's don't count in my book I was not aware of that fact, thanks for pointing it out.
Old Jun 16, 2008 | 11:37 PM
UP_There's Avatar
UP_There
Both were unplugged after I went to the 6637........never had any issues since.
Old Jun 17, 2008 | 07:37 AM
rebelchevy02
I actually think all the common rail style diesels do aswell. I remember seeing info about somebodys aftermarket intake causing codes/trouble on the 6.4s. However, Im really not up to date on other motors. But Im pretty sure the big 3 all have MAFs now.
blink0404
New Member Introductions
Sep 8, 2007 07:13 PM
ltfire99
Jul 3, 2006 08:37 PM
quadzjr
Dec 12, 2005 11:59 AM
ExpoBoi99
Jun 21, 2004 04:25 PM
firewood1
Nov 28, 2003 06:29 AM
