Where is mass air flow sensor?
Old Nov 22, 2003 | 07:44 AM
firewood1's Avatar
firewood1
I have a 1996 F150 with a 4.9 liter engine. Where is the mass air flow sensor located? Also, where is the PCV valve located?
Thanks
Old Nov 22, 2003 | 10:15 AM
95 F150's Avatar
95 F150
The mass air sensor is attached to the black air filter housing (air box). It's the round silver piece that will have a plug in connector on it. The link below will give you an idea of what to look for. The pic in the center of the screen is airbox and mass air assembly for 5.0 efi should be pretty close on the 4.9 I6.
http://www.speedfreaksspeedshop.com/...dept_1333.html
Keep on truckin' ...Mike
Old Nov 22, 2003 | 01:40 PM
Vanhecht's Avatar
Vanhecht
pcv valve should be on the rear of the valve cover
Old Nov 23, 2003 | 06:19 PM
steve83's Avatar
steve83
The MAF is the silver thing in the foreground between the air filter box and the plastic pipe to the intake.
Old Nov 24, 2003 | 05:57 AM
firewood1's Avatar
firewood1
Thanks everyone!
I wonder how hard it is to change out the mass air flow sensor?
Old Nov 24, 2003 | 06:08 AM
pfogle's Avatar
pfogle
looks like 4 studs, 1 electrical connector, and a hose clamp.
Old Nov 28, 2003 | 06:29 AM
firewood1's Avatar
firewood1
I checked and cleaned mass air flow sensor
It was clean as a whistle. While I was doing this I noticed some hoses that were broke in two. They are located about one foot upstream from the mass air flow sensor. They tie in to the fuel injection (manifold?) then they come together and tie into something over by the A.C. Could this relult in the left bank lean, right bank lean reading?
Selfhl1
Dec 8, 2015 10:13 AM
jerkypants
Oct 29, 2011 09:17 PM
baseba8311
3.8 & 4.2L V6
Jun 26, 2007 09:06 AM
Carp31
Sep 13, 2005 06:55 PM
adrianlovessnow
16
Apr 8, 2004 11:03 PM
