Mass Air Flow Sensor Replacement
Old Jun 21, 2004 | 08:51 AM
ExpoBoi99's Avatar
ExpoBoi99
I have to replace my mass air flow sensors on my truck, I can get the part for like 130. Can I install this myself or should I have a shop do the work??
Old Jun 21, 2004 | 09:51 AM
buzzard's Avatar
buzzard
You ought to do it yourself. The MAF sensor is "stuck" into the air intake between the air filter box and the throttle body. All you have to do is remove the old and insert the new. There was a tech article floating around here a while ago....may have been on the f150 forum or the ranger forum.
Old Jun 21, 2004 | 10:51 AM
ExpoBoi99's Avatar
ExpoBoi99
ok so after i put the new one in should i also reset the computer on the truck also?
Old Jun 21, 2004 | 04:25 PM
buzzard's Avatar
buzzard
Definitely. Just disconnect the battery for 15 minutes and turn on headlights (to make sure all juice is gone).
Helipilot2
1978 - 1996 Big Bronco
Jan 1, 2013 10:15 PM
SWA2004
2004 - 2008 F150
Mar 26, 2010 08:41 PM
unioncreek
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 19, 2007 10:52 PM
ltfire99
Jul 3, 2006 08:37 PM
quadzjr
Dec 12, 2005 11:59 AM
